Question about Maytag Washing Machines
My Maytag Centennial washer stops after filling,sometimes it will wash, then stop, with just a loud motor hum that doesn't stop unless I unplug it.there is a lot more but says it's to long
Leaves black gritty stuff inside tub and all over clothes
  • Brad Brown Dec 02, 2016
    Hi Deb Thomas, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number
aborcass
  • 2651 Answers
SOURCE: KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Posted on Jan 31, 2009
beltronic205
  • 1474 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
  • 62 Answers
SOURCE: I have a problem with a Maytag Washer Model Number
sounds like your belt is slipping and burning inspect that for wear. or you may have a pully prob
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: MY MAYTAG MTW5800TW TOP LOAD WASHER WILL NOT GO
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Posted on Nov 24, 2010
Washer will not spin
sounds like u might have broken a belt need to take it apart back side where motor is and their should be a belt there try not over loading it thats when it usually happens
Mar 17, 2013 | Maytag Centennial MTW5800TW Top Load...
Maytag Centenial water fills the frist time but then the washer stops.
Your timer is done for. It needs replaced. The gears inside are worn down/out.
May 15, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
After the tub fills with water, I hear a humming sound for several minutes then I hear a "click" and the humming sounds stops. I notice the motor is really hot. Is it a bad motor, or could it...
I suggest that you first check to see if the drum and pulley are turning freely, that there is nothing seized. Also, sometimes having a deteriorated drive belt (the one that goes to the drum pulley) can cause the drum to put too much strain on the motor and make it overheat. So it may not be time for a motor just yet, but if everything is spinning freely then you may just have to get another motor.
Jul 23, 2011 | Maytag Centennial MTW5800TW Top Load...
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag hav2558aww stopped working. It is full of
Either the fan belt is broken or worn out. Or you need a new motor
Nov 03, 2009 | Maytag HAV2558 Top Load Washer
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
