Question about Honeywell Heat/Cool Thermostat
Will TH6110D1005/U replace T8112D1005? have latter & cant get bat lo to go away even with new batts
  • 232 Answers
SOURCE: Batt Lo Displayed. I replaced with new batteries.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Posted on Oct 28, 2009
Testimonial: "Thanks! It appears that you are right--I even tried other "new"batteries....Off to buy a new thermostat."
  • 254 Answers
SOURCE: The bat lo message will not go away even after
One thing you might want to try is to remove the batteries and wait for a few minutes until everything clears. It could take around 10 minutes or so. This will reset the thermostat. Also look on the back and/or on the board of the thermostat to see if there is a reset button.
I hope this helps! :)
Posted on Oct 29, 2009
james3751
  • 614 Answers
SOURCE: bat lo flashing periodically
You need to change batteries. The bat lo light flashes when you have about 10% battery life left. Rus
Posted on Dec 05, 2009
Testimonial: "Thank you - since the thermostat is hard wired, I didn't realize it had batteries. Your tip is very much appreciated!"
  • 6 Answers
SOURCE: I replaced the batteries, but it still says lo
in some thermostats it is required that you have a common lead hooked to Thermostat and back too the transformer in the air handler unit the batteries are used as a back up in the event the power goes out too keep your program in thermostat. if the common lead is not attached your thermostat is being powered by the batteries only and not the system control power, and will drain batteries fast.
Posted on Sep 16, 2010
SOURCE: I replaced the batteries in my Honeywell CT3300
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Posted on Nov 23, 2011
Thermostat display reads lo batt replaced batt still reads lo batt
Suggest have battery tested.
Most thermostats cost more to repair than to simply replace them.
Feb 04, 2018 | Heating & Cooling
System lo bat
Most likely it's your back up battery. It should be with the panel in a metal box. If you have a wireless system the zone number will pop up on the screen at the same time the "lo bat" does.
Oct 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
May 09, 2011 | Honeywell Programmable Thermostat Heater
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
Dec 04, 2010 | Honeywell Programmable Thermostat Heater
Even after replacing the battery, the programmable Honeywell thermostat still shows "Low Batt."
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Jan 26, 2010 | Honeywell Programmable Thermostat Heater
Bat lo flashing periodically
Dec 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
The bat lo message will not go away even after replacing batteries.. No functions either
Oct 29, 2009 | Honeywell CT3200 5-2 Day Electronic...
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Heat/Cool Thermostat Logo
120 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Dan Webster
Dan Webster
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
