Question about Venmar Kitchen Ranges
The lights on my Venmar Jazz range hood VJ60430SS turn off. I hit the switch a few times on and off and they come on again. It's like they heat up and then shut off.
  • 203 Answers
SOURCE: Range hood light switch not working.
you have checked the bulb? if so the the switch of disconnect from supply first and have a look at the condition of the switch it might be full of goo. joe
Posted on Nov 22, 2008
  • 136 Answers
SOURCE: Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Posted on Jul 07, 2009
SOURCE: Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
Posted on Feb 25, 2010
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
  • 4 Answers
SOURCE: #23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
Posted on Dec 01, 2011
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M ยท Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Turned of the light on my hood and nothing worked after. No light no fan.
Some units have a reset button on the unit some place Check and see if you have one and push to reset. Hope this works for you.
Sep 15, 2015 | Venmar Kitchen Ranges
Change a lightbulb(won't budge) in a venmar 430 or 330 range hood
Get a new bulb and look at it, that will help as not all bulbs have the same base.
Dec 13, 2014 | Venmar Kitchen Ranges
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Dec 01, 2011 | Kitchen Ranges
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
Sep 06, 2009 | Venmar Kitchen Ranges
We canot find a part: the plastic cover the light bulbs
Try universal Appliance parts store..google it for a location in your area...
Feb 11, 2009 | Venmar CONNAISSEUR 1200 Kitchen Hood
Electronic Control Not Working
The electronic controller is faulty. You will have to contact the supplier where you purchased the rangehood from to find out who the warranty agents are for that make & model.
Nov 03, 2007 | Venmar CONNAISSEUR 5000 Kitchen Hood
Kitchen Ranges Logo
135 people viewed this question
Top Venmar Kitchen Ranges Experts
Gil Shultz
ray gallant
Dan Apthorp
Are you a Venmar Kitchen Range Expert? Answer questions, earn points and help others
