I've plugged all relevant plugs in right places. But nothings happening .nothing come on television x
  • 5 Answers
SOURCE: cuisinart 11 cup processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
  • 3 Answers
SOURCE: Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Posted on Mar 04, 2009
pshinde23
  • 136 Answers
SOURCE: i have plugged in my speakers at right place but no sound.
Try changing the setting from the "Realtek HD Audio Manager" Select the correct input jack, double click it then "Which Device did you Plugin " window will pop up select the appropriate option and shall work. If this Does not work disconnect the speakers from the system, remove the sound drivers & reinstall it again, connect the speaker. This shall work now
Posted on Jun 25, 2009
  • 270 Answers
SOURCE: Camera isn't detected anymore by my computer.
Go to your start menu>all programs and look for it.
Posted on Jul 08, 2009
AldRezaine
  • 995 Answers
SOURCE: plug in my hard drive and nothing happens
Make sure that your usb hard drive is inserted properly into the computer but if nothing happens, go to your bios settings of your computer and be sure that usb function is set to on. Save changes and restart the computer. If you dont know how to do this, first turn on the computer and press the delete key in the keyboard, once you enter the bios screen look for the usb settings and make sure it is set to on. Hope this could help. Thanks
Posted on Oct 23, 2009
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
Dell Precision M6300 turns on and then nothing happens.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Dell Precision M6300 Notebook
When my tv is powered on, it displays the device menu and continues scrolling through it, but will do NOTHING else. I've tried to reset, and nothing. The tv will not respond to the remote at all.
A suggestion here: If possible to remove front speaker grill and inspection plate that should be behind it---locate the bundle of wires that comes down from front keyboard with the buttons and follow it to the right and down---should be one or two plugs in-line--------disconnect them with the set off and power set back up with remote.
If the problem is gone you have a bad micro-switch on the front of the set------buttons on the keyboard there have priority over the remote---hence you cannot if the problem is there stop it with the remote or do anything for that matter.
Let me know what happens and I will suggest options.
May 31, 2012 | Televison & Video
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am trying to hook my ps2 up to my tv but i plug the cords into the right spot and nothing happens. I dont no which channel it should be on or what imput.I tried all the imputs and still nothing
Make sure you are plugging into the composite ports and not the color ports. and make sure your input setting is on the right ports too.
Feb 03, 2011 | LG 32LC2D Television
My Franklin have new batteries, I press the key ON and the screen no showme nothing and nothing is nothing. What happenned? What can I do?
Please check if the batteries are placed in the right order. The +ve symbol on the battery should be placed across the +ve symbol on the battery space of the translator. Likewise the -ve symbol should match with the -ve symbol on the device. Try placing the batteries so that they match with the symbols specified on the translator's battery area and switch on the device.
Nov 02, 2010 | Franklin Office Equipment & Supplies
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
