Print quality is not dark - Office Equipment & Supplies
    Top Expert:
  • Office Equip... Master
  • 8,211 Answers
2 Suggested Answers
  • 43 Answers
SOURCE: print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Posted on Apr 01, 2010
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
I have a Zebra 170Xi II & Zebra 170Xi III plus and the problems is that they print really good at low speed but in high speed it doesn't print almost anything. Already set the darkness of the printer...
if you increse the speed, you need the incrise the darkness, clead the printhead and the white rollar, you can improve the quality if use the correct ribbon and the relation between the ribbon and the paper of the lables are the best. chech with your Media suplier. The problem with the increse speed and the darkness can damage the printhead, and they very expensive.
Nov 01, 2010 | Zebra 170Xi II Thermal Printer
Print quality: dark faded, but continuous
Apr 01, 2010 | HP LaserJet 4 plus Printer
The photos are coming our dark
Hi
Check the Following link for Enhance Image
HP ENHANCE Image
  1. From the application you are printing from, click Print , and then Properties . The Print Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Select dpi (light to dark )
  4. Click OK .
Jan 04, 2010 | HP Photosmart 8250 InkJet Printer
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Printing fades during the print job. Dark at beginning, gets lighter to unreadable.
Is the ink cart. good? If not, replace.
Are the Print Heads cleaned? If not, run the diag to clean.
Does this happen on all print jobs? (documents, images, etc..)
If not, then try to adjust the properties of the print driver to a lesser quality.
Sending higher quality print jobs takes up memory, try to increase your page file.
Aug 07, 2009 | HP D4360 DeskJet Printer InkJet
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
Color printing
To get the optimum quality print for your color prints of course everything has to be set just right. On your printer installation and print menu it will ask you if you want letter quality print or picture quality, make sure that you are using the right options in this case. Also be sure that all your ink cartridges are at least half full for print purposes. God bless you
Jan 10, 2009 | HP LaserJet 2840 Printer
Copying quality is not good
you need to make carbonation form the tools
if the bad quality form the print you need to to change the defaults print
best regards
Nov 26, 2008 | Canon (6981A002AA) for imagerunner 2200,...
22 people viewed this question
k24674
jasbo
jasbo
