I live in CST time but I have to set clock to MT to get the right time
I put the clock on CST and the next morning it gives me EST
5 Suggested Answers
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Posted on Dec 21, 2009
SOURCE: I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Posted on Feb 24, 2010
SOURCE: My clock did not automatically set itself to
je voudrais la notice pour remetre a l' heure mon horloge
ref : orium hd 1688
Posted on Apr 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: bought a new RCA clock
I would think there would be an indicator. This old-style manual is online.
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RP5435_EN_2EAC.pdf
This site invites technuical questions.
http://www.rcaaudiovideo.com/support/
Ask them about the new style Time Zone control.
Posted on Apr 26, 2011
Clock face does not show DST. When clock is set to correct time, it turns back one hour at midnight.
DST start and stop was changed a few years back. If you clock has embedded code with the old start and stop, the only way to fix it is to turn off automatic DST. Not sure what clock you are using however it appears to picking up the current GMT time. Another cause is if you have a time zone setting, CST, EST, PST etc.
Mar 20, 2016 | Audio Players & Recorders
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
How to set
Hello
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 15, 2010 | SkyScan 86742 Digital Atomic Wall Clock
I am getting EST time. I live in MST. How do I reset the time ?
Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 02, 2010 | SkyScan 86709 Atomic Wall Clock
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Digital atomic clock radio
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
Mar 31, 2008 | SkyScan 34202 Clock Radio
Setting the time
On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
The third is just the brightness.
Now, to set the time itself:
1 - Turn the clock face back up to where you can see it.
2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
Good Luck!
Mar 16, 2008 | RCA RP5420 Clock Radio
42 people viewed this question
 Grubhead
Grubhead
