Question about Big Button Lands Phones
How can I change time et date on my new Nexxtech big button telephone ? It is not indicate in the manual instructions
CORDLESSGURU
  • 106 Answers
SOURCE: Toshiba DKT2020-SD 20 Button Display Speaker Digital Telephone
To change the time, go to extension 10, while keeping the handset on hook, push intercom, then dial # 6 5 2, enter the new time ie. 102510 (hour, min, seconds), then push the redial key to save. That should do it. to set the day use the intercom # 653 code (1=Sun, 2=Mon, ect). To change the date use the intercom # 651 code (ie. 080510). If that does not do it, you may have a different model key service unit, and you will need to notate which system your using.
Posted on May 10, 2008
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
  • 18 Answers
SOURCE: I need to change to time and date on my T7208 telephone
On the right hand side of ur keypad there will be 8 buttons. Third button from top will be ur change button if u r using T7208 or M7208 phones.
Thanks.
Abhi
Posted on Jul 12, 2009
  • 279 Answers
SOURCE: Ilost the instruction sheet for my new nexxtech
Google search " nexxtech support" go to the web site and you will find the manual. You need to have the model number.
Posted on Sep 19, 2009
  • 945 Answers
SOURCE: How to set date and time on Comdial 8024S Impact Telephone
http://dl.owneriq.net/d/d1f52d1e-de34-4f20-a842-8a329b5ad24d.pdf
Above is your manual.Date and time is on page 113 of pdf or page 103 of manual.
Hope it helps!
Posted on Jan 03, 2010
My 86 year old mother got a nexxteck big button telephone for xmas we just hocked it up and the user guide is not for the phone she has
You can find the manual here: http://www.mts.ca/file_source/mts.ca/Static_Files/Raw_PDF/NexXTechUsermanual.pdf
May 04, 2011 | NexxTech Lands Phones
Need setting instructions for Nexxtech model 631 1461 upright weather trend alarm clock
Nexxtech Instructions
1. Press Mode button to toggle between year, time, and alarm.
2. Press & hold Set button in each mode to make changes. For example: In year mode press & hold Set until year flashes then press the Adjust button to make the change. Press Set again to change month or day. Use same procedure to change time or alarm.
3. Press Mode button again to return to normal operation.
Note: You can't change the temperature, humidity, or weather trends of course because they are what they are.
Nov 29, 2010 | Office Equipment & Supplies
NEXXTECHâ„¢ BIG BUTTON CALLER ID# SPEAKERPHONE\r\n message waiting indicator will not turn on.took phone back they gave us a new one and it still doesnt work. We subscribe to call answer thru the phone...
Message waiting is sent to subcribers in 3 ways; by a method called FSK, by "stutter" dial tone, or by voltage. Since you're the one looking at the model number and/or the manual, you need to find out which one you telephone company is sending and buy the appropriate equipment.
Since you've tried two phone, I'm guessing that it is just not compatible with what your telco is sending.
Carl
Sep 11, 2010 | NEC Lands Phones
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
I work with the local telephone company a customer is having problems with their call display do you have an 800 # which she can call or a suggestion which I can give her to check the actual phone she has...
Here it is Nexxtech contact details: Contact Us: Phone - 888-319-9464
Hours of Operation - 8am-12am CST, 7 Days a week
Closed - Thanksgiving Day and Christmas Day
Ryan
www.cobaltsys.net
kbretrieveimages.php?id=1899
Oct 13, 2009 | NexxTech 4318570 Corded Phone
Jun 08, 2008 | Big Button TV Universal Remote
AT&T phone and answering machine combo 9351 need instuction manual to reset time and date!
9351: http://telephones.att.com/docMgt/public/art/339/9351_manual.pdf
1818: http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=286
Dec 15, 2007 | AT&T 1818 Corded Phone
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Lands Phones Logo
32 people viewed this question
Top Big Button Lands Phones Experts
Tom Chichester
richie46
Are you a Big Button Lands Phone Expert? Answer questions, earn points and help others
