Question about Dishwashers
Curry essential CDW 60 We 10 fills and empty soon after with Beeb's and flashing fourth light control side
2 Suggested Answers
  • 42916 Answers
SOURCE: Hi why is my curry essentials dishwasher leaking water when is is fill up
Defective or missing float switch
Posted on Oct 09, 2016
Series of lights flash on control. Why no response?
Most likely cause is the joystick is in LOCK mode.
Turn Off and On
Hold joystick forward till you hear a beeb
Hold joystick back until you hear a beep
Gino
Jun 30, 2015 | Pride Jazzy Select Gt With 2 Batteries In...
I have a problem with my curry essential dishwasher CDW60W13 The 1hour light keeps flashing what could this be I have no manual so I can't find out what this is in need of help please
I have a similar problem with my DW, hour light flashing and pump run constantly, and have located my problem.
The hand book points towards a faulty float switch, and this is fixed to the base plate of the machine.
First of all, disconnect the machines from the mains, then tilt the machine at an angle of approx 45 degrees and see if any water comes out onto the floor. If so, this indicates there is a leak causing the water to collect on the base plate, and activating the float switch.
I then removed the base plate (4 screws), take care removing this as the electrical connections restrict movement. Check the hoses underneath. I found a split in the black hose that connects the element to the pressure switch and top spray pipe.
I am now trying to source a new hose and hope to have the machine up and running again in a few days.
J
Oct 01, 2014 | Dishwashers
Currys essentials dishwasher error warning
Just installed a CDW60W16 at my daughters house. worked ok empty but as soon as it was loaded the glass icon lit up and beebs. when I turned it over to take a look at the float switch I noticed that the levelling legs were all screwed in so the base of the machine was sitting on the floor. so when the machine was loaded the pressure switch operated as it was being pushed up by the floor. I unscrewed the legs a few turns to allow an air gap between the floor and base of the machine and all working fine now. on checking the installation instructions it only mentions loosening the legs to level it if required which is wasn't. maybe the manual should give instructions to unscrew the legs a few turns to prevent this
Aug 24, 2012 | Dishwashers
I have a SGV43A03GB Bosch dishwasher that has run perfectly for several years and now stopped. Essentially all the lights remain on, there is water in the pan (indeed it fills after having been emptied...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Also if the Inlet valve is staying OPEN and the drain pump is working as soon as the machine is switched on then it can be fault in the controller unit.
Jul 07, 2011 | Dishwashers
I have lost the instructions to my essentials crc2n110, i need to programme it to my tv, how do i do this ?
I had exactly the same problem . I discovered it is a re-badged HAMA Universal Remote. The link here http://www.hama.com/00011413/hama-universal-8in1-remote-control is for the 4 and 8 in 1 remotes but the instructions on the PDF files do work, I tried with my Curry's CRC2N110. Hope this helps!
Jul 04, 2011 | Televison & Video
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
Service Engine soon light cam on after filling up with gas. I checked the gas cap several times and the light stayed on. I had an oil change and the light went off and stayed off for days. Yesterday it...
this happened to my dads truck and after he would fill up with gas his dashboard would light up like the fourth of july. the problem is a little computer motor inside the dashboard that costs about $2. but if u take it to a shop its about 700$
Mar 10, 2011 | 2002 Mitsubishi Galant
I have a side/side model KSRD25FW15. Can get water thru door but won't fill ice trays. Why won't ice trays fill?
That is most likely the water control valve on the rear of refrigerator and near the floor. If the ice maker is empty fill with tap water and let it freeze. If it dumps and does not refill the water control valve for the ice maker is defective. I will get back soon with the parts number. Thanks, Sea Breeze
Aug 17, 2009 | KitchenAid Refrigerators
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
