How long does the water pump belt last on these pro heat washer?
  • Washing Mach... Master
  • 17,326 Answers
You did not post the make and model number but I am not aware of any front load style washers that use a belt on the pump.
Posted on Dec 02, 2016
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Bush manuals
hi there.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
or read up more at this link might help you some more.
washing machine wont spin or drain Google Search
Dec 12, 2017 | Washing Machines
When do I replace the timing belt and water pump on a pontiac 2008 G6?
The timing belt last for a while. Probabbly change between 100,000-120,000. The water pump dont need changed until it is broke. When so, your heat wont work or your car will overheat.
Feb 16, 2011 | 2008 Pontiac G6 Sedan
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Pro Heat 2X will not spray water and/or solution
There are 2 belts. One for the brush assembly and one for the pump. Generally when they will not spray the belt for the pump is worn and slipping.
Nov 30, 2009 | Cars & Trucks
Water standing still in tub after load is done!
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 04, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
GE WASHER WJSR4160GWW Won't Agitate
Sounds like tub belt failure. Check online for model layout. If unit is belt driven, remove back panel to access internal works. Look for broken belt. Depending on setup, control system stuck on water pump. Else possible control panel failure or motor (if water pump separate).
Jul 10, 2009 | Washing Machines
My 1991 dodge caravan started having problems last night..
yes check belts ..and the cause .. a frozen water pump or other accessory that is turned by the belts frozen ... then advise me
Dec 08, 2008 | 1991 Dodge Caravan
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
