Question about Microwave Ovens
Keep running when door is closed - Microwave Ovens
  • Brad Brown Dec 02, 2016
    Hi archie pool, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make and model number
My microwave keep working when I open the door and it is stopping when I close the door.Then working normal but I cannot keep my door open, it keeps running. What can I do??
First, It is very very dangerous for a microwave to run with door open. The door is also a shield to protect you from the microwave radiation. There should be a safety interlock to prevent this from happening. DO NOT USE the microwave! Seek out professional repair or replace the unit.
May 20, 2015 | Microwave Ovens
Why does my microwave keep running/heating until I open the door? what can i do about it?
Sounds like a problem with the control panel. Further diagnostic testing would be required, however, as there can be other causes.
May 10, 2014 | Oster OGB61101 Microwave Oven
Why does my emerson microwave keep running after you close the door
Possible that there is fault in the main control board as the processor seems output the drive when the door is closed and not when the start is activated. You can check the customer panel and clean the switch pad, dry if there is moisture, clean the inside of the board, use jet air to clean. If not the board could be a suspect.
Feb 11, 2013 | Emerson Microwave Ovens
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
My microwave keeps running....meaning when i close the microwave door it will automatically run.
The timer control has the problem so it need to be replace. But be sure you do not program the microwave to auto run when the door is close some microwave have that feature.
Hope my advice help you.
Apr 04, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
