Question about Apple 13.3 MacBook Intel Core 2 Duo 2.0GHz, 2GB, 250GB, SuperDrive - Aluminum Laptops Mac Notebook
My macbook won't boot at all, not even to the gray screen with the apple on it. I can hear it trying to boot, as the cd drive makes its typical noise when you turn it on. It was kernel panicking earlier and wouldn't stay on for more than a couple of minutes, but now the screen is just blank.`
  • 30 Answers
The problem you describe is more like a video card gone bad and that is directly related to the logic board. You can follow the instructions that shawty-lozzy gave you before and try with and external monitor (just to make sure it is not video) but if you don't see anything that way... the logic board is probably gone and unless you have AppleCare, it is an expansive repair. Good luck!
Posted on Jul 24, 2009
    Scholar:
  • 151 Answers
Put the install disk that came with your laptop into your laptop, hopefully it might boot into the disk, what you have to do is hold down C until it boots. then fix the problem with utility manager.
I hope that works for you since the screen will not show the grey screen. If this does not work, there may be something wrong with the screen or the firmware, if that is true then i would suggest taking to your local Apple store and explain your problem to a mac genius and they will sort you out in no time.
Hope i have been helpful,
Regards
Posted on Jul 21, 2009
Will come on stuck on gray with an apple and turning wheel
This happens when your computer can't find and load the operating system. You need to start from another CD or hard drive so you can run the Disk Utility program. Try using your original operating system CD that can with your mac and press the either the control key and the C key or just the C key to force the computer to boot (start up) from the CD rather than the internal hard drive. Then ignore the messages on the CD to install the operating system and find the Disk Utility program in the pull down menus at the top. Find and select your internal hard drive for it to repair. If you cannot find it, likely your hard drive has crashed. You will need to replace it and install a new operating system on it.
In that case, your data may be lost on your old hard drive.
If you have a external hard drive, depending on the interface, plug it in to the appropriate connector (firewire for example) and boot from the hard drive, then run the Disk Utility program from there.
If you have no operating system CD, try to borrow or buy a copy, it must be of a version that will work on your model of computer.
Apr 08, 2014 | Apple MacBook Air
Apple MacBookPro 2010 is in a white screen
If the start up sound plays and the hard drive sounds normal try connecting the computer to an external monitor. If the external monitor shows the desktop just fine then the cable connecting the laptop to its screen is probably going bad.
If the computer will not boot at all try zapping the PRAM by
  1. Pressing the power button and then command-option-p-r before the gray screen comes up.
  2. Hold those keys down until you hear the startup chime.
  3. Let go of the keys and let the Mac reboot.
If that doesn't work try booting from an install disk and run a repair utility.
Jan 28, 2014 | Apple 13" MacBook Notebook Computer ...
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
Apple macbook air won't turn on
Does the Apple logo or the Pinwheel show on the screen?
There is a problem with you OSX installation. Please boot from the Recovery partition (hold Cmd+R during the startup chime), and use Startup Disk to choose the correct hard drive to boot from.
You can also restore from a backup, and not lose your data here as well.
Oct 28, 2012 | Apple MacBook Air
My macbook won't start. how do I eject an audio CD?
You could be right. What to do is start it up and hold down the trakcpad button as soon as it starts up. Failing that try the F12 key or the eject key when starting it up, sometimes actually lifting the macbook up and pointing the DVD drive downwards i.e. using gravity to let the CD drop.
If the CD ejects and it isn't the problem causing the startup problems, what I would be tempted to do if the other troubleshooting solutions have not worked, if it still under warranty or if you have Applecare, contact apple and arrange to get it taken in for repair. Failing that take it to your local Apple Store and make an appointment at the genius bar, they usually are fairly good at diagnosing problems and solving them.
Jan 02, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When booting up my laptop it has a gray screen with the apple for a minute and then it turns to a circle with a slash through it
Boot from the CD/DVD that came with your Macbook. Launch 'Disk Utility' and perform 'Repair Disk' as well as 'Repair Disk Permissions' on your boot drive and hopefully that will fix the issue.
If that doesn't do it, try holding the Option key during startup to select the boot disk and select your Mac HD. If it boots in this manner there are rumors about some bad SuperDrives out there causing this boot issue. So you may want to boot it while holding "D" and run the Apple Hardware Test from the DVD/CD.
Mar 19, 2010 | Apple MacBook Pro Laptop Computer with...
MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Trying to fix a grey screen problem on a macbook. I tried to reinstall the cd and it stuck with errors report. Now it won't reinstall or boot from the cd. When I check the disc utility it says, capacity...
Since no MacBook was ever made with an 8GB hard drive, I have to assume you are reading the capacity of the DVD, which isn't an interesting statistic.
There is no reason your MacBook should not boot from the DVD. Even if the internal drive was physically absent it should still boot from the DVD.
If it is not booting from the DVD, then either your DVD is bad, your optical drive is bad, or you have logic board issues.
Sep 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Will not start. Goes to a gray screen with apple on it then stops
You may need to boot from the MacOS X CD to do a repair. Insert the CD in the drive, and restart. Keep pressing the C key to boot from the CD, once the CD boots, you may have options to repair your MacOS installation, or alternatively reinstall the system software.
May 24, 2009 | Apple iBook G3 Mac Notebook
Apple 13.3 MacBook Intel Core 2 Duo 2.0GHz, 2GB, 250GB, SuperDrive - Aluminum  Laptops  Mac Notebook Logo
469 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
