Question about Pool & Spa
My Hot Springs Sovereign jet pump starts running without being switched 'on'. Turns off with the switch, but then, later, starts running again. Aux. control panel lights function quit, also
    Top Expert:
  • Pool & Spa Master
  • 7,915 Answers
See if heat on maintain if so take off
Posted on Nov 12, 2017
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
SOURCE: I can switch on lights and fan, but then they switch off
It could be either. Usually i would say its the control board, but its very possible that its the transformer. I would start with that, the trans=25$ then control board = 110$
Its the small transformer (blue/yellow/black/white) wires coming out of it.
Posted on Feb 08, 2009
seans46
  • 161 Answers
SOURCE: 2004 Suburban rear blower motor not working !
You will have a blower motor resistor that controls power and the speeds to the blower motor it will be by the blower motor and is cheap new.
Posted on May 24, 2009
dltatsjc
  • 54 Answers
SOURCE: My water pump stops and starts. the contacts on
A lot of these pumps do have automatic thermal switches built into the motor end cap, Double check that its being fed the name plate voltage and that the voltage doesn't drop when the pump is running (which would indicate a loose or bad connection or just undersized wire in the circuit)
Posted on Dec 12, 2009
Coastsider
  • 331 Answers
SOURCE: I have a 2000 Sovereign Hot Spring hot tub that
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
Posted on Apr 14, 2010
Circulation pump won't run
Could be as simple as turning off "Summer Mode" that should only be used in very hot climates.
Hold both temp buttons (+ -) in until icon on display is gone.
Dec 05, 2013 | Hot Spring Spas Iq 2020...
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Maax tub
Some air jet bubbler blowers are designed to run for 5 to 10 minutes after you drain the tub to push all of the water out of the air channels. It should shut off on its own once it senses all of the water has been blown out. If it continues to run much longer than that, then contact the mfg for a service call. You have a warranty if it is a recent purchase that should cover it. Hope this helps!
Sep 10, 2017 | Home
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
I have a 3/4 hp shallow well pump. It running at about ten on my pressure gauge. That means no pressure. What can I do?
If the pump turns on and off real fast, then your pressure tank is water logged. If you have
a pressure tank with a diaphram in it, you need a new tank. If it's a plain tank, then you
need to turn off the pump, drain the tank and turn it on again. All pressure tanks need
a cushion of air on top.
If the pump isn't short cycling, then try adjusting the pressure switch. There are two springs
under the cover, with adjusting nuts on them. One is for the cut in, the other is for the cut out.
I would set it so the pump turns on when the pressure drops to 30, then turns off when it hits 50.
Hope this helps ya !
Oct 31, 2010 | Flotec Corrosion Resistant Shallow Well...
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Car turns but won't stay running
Check fuel pump fuse and all other fuses, check brake switch, Also, a worn ignition switch will cause the car to start sometimes but not always. Try turning the switch to on position, then jiggle the key around in the switch while pushing in a bit...now start the car...did it start? If yes, replace switch and/or key cylinder....
Dec 03, 2017 | 1991 Honda Accord
Hi
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pool & Spa Logo
143 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
