Question about Speed Queen Washing Machines
Error code ED44
Goes through a full cycle then shows out of order and ED44 code
2 Suggested Answers
mccluskey1
  • 4775 Answers
SOURCE: Speed queen error code Ed44 what is this?
this is all i can find..
Speed Queen Fault Codes ..
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Speed+queen+error+code+Ed44+what+is+this
Posted on Dec 15, 2016
Speed Queen front load commercial washer - error code ed44. What does this mean/
Overcurrent Shunt Detection,Circuit Fail Error
Hardware failure. Unpower to clear error. Replace drive board if error persists.
May 04, 2017 | Speed Queen Washing Machines
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
E90 error
The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
