Question about Epson WorkForce WF-3620 Wireless Color All-in-One Inkjet Printer
How do i fix error code 0x88 turn off and on again in Epson 3620 workforce
graysand
  • 558 Answers
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Posted on Sep 21, 2009
TJ4722
  • 54 Answers
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Posted on Dec 13, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
cns assoc
  • 677 Answers
SOURCE: i have 2 epson workforce 1100
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 05, 2010
pineworks
  • 4041 Answers
SOURCE: epson workforce 600 displays message
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
How do I fix error code 0x97 on Epson printer
0x97 is a scanner circuit board error. You can reset your printer by unplugging it from the wall for a few minutes, and then trying again. Unplug is not the same as "turn off". Other than that, service center is your only answer.
Jul 05, 2016 | Epson WorkForce WF-7620 Wireless Color...
I cannot find the online user manual for the WF-3620!
You can find easily by google it, Just type the model number of printer with user manual or user guide
you can use this key work " epson wf-3530 user's guide "
https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?UseCookie=yes&oid=232591&infoType=Doc
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
Feb 01, 2016 | Epson WorkForce WF-3620 Wireless Color...
What is error 0X97?
I think that is a printed circuit board (PCB) problem and is not user repairable. You might try unplugging the printer, wait about 10 - 15 minutes, hold down the power on button and plug the printer back, continuing to hold down the power on button for at least 60 seconds. If it doesn't clear the error code, it's a circuit board problem. If the printer is out of warrantee, it's cheaper to buy a new printer.
Aug 29, 2015 | Epson WorkForce WF-3620 WiFi Direct...
How do I fix "Scanner Error 4D" on my Epson WorkForce Printer?
Unplug the unit for half an hour or so. If no results, try again.
Apr 02, 2015 | Epson WorkForce WF 2650 All In One...
Epson wf-2540 Scanner error
Hi Richard,
I suggest You Go to Official Epson Printer trouble Page For You Epson Printer Problem On Below Epson forum URL Link:
Epson WorkForce WF 2540 All in One Printer
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Epson Printer Support
Feb 11, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Epson WorkForce WF-3620 Wireless Color All-in-One Inkjet Printer Logo
286 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
