Question about Husqvarna Garden
Yes, there is a throttle return spring. Usually this is located inside the throttle assembly.
Posted on Feb 22, 2017
SOURCE: How do I take gas tank off of a Husqvarna 125B gas
Hello . First you have to remove the 3 nuts holding the plastic back part . 2 nuts are on the bottom and one at very top of the machine .
Then you just have to remove the 3 phillips head screws holding the tank and remove the fuel line . Hope this help .
Posted on Aug 29, 2009
SOURCE: how do you install primer bulb on husqvarna 125b
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
SOURCE: Engine cut out
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Posted on Sep 11, 2009
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Posted on Nov 23, 2009
SOURCE: Husqvarna backpack blower 40 B stalls when going
The unit is running like that because of a lean condition. Depending on the situation it can be solved by adjustment ( Im thinking your particular unit may not have any adjustment) , rebuilding the carb ( carb kits are $15-20 from your local Husqvarna dealer), and/or replacing the fuel lines.
Posted on Dec 01, 2009
Testimonial: "Thanks. I'm thinking the carb needs rebuilding and fuel lines could be an issue. In checking some prices with Husqvarna 60 to 70 bucks to rebuild."
May 05, 2017 | Husqvarna Garden
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Apr 22, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Apr 12, 2013 | Husqvarna Garden
Feb 02, 2013 | Husqvarna Hand Held Blower 125 B Grass...
Jan 26, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
May 26, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Nov 22, 2009 | Husqvarna Garden
107 people viewed this question
