Question about Hardware & Accessories
Aube TH132AF control module switches off when it tries to activate
2 Suggested Answers
SOURCE: aube CT280-2H1C exit pin for humidifiers dont give 24vac
My carrier humidifier does not show any runoff of water in the over flow. it does not appear to be getting water
Posted on Feb 17, 2009
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
I am trying to hook up an utilitech timer.it has 1 red 1 black 1 green and 1 white wire. The switch I am replacing it with is in my entrance but there is also a switch in the garage for these lights. I...
Utilitec timer will not work for 3-way switching.
When 2 switches control same lights, then that is called 3-way.
Utilitec is for single pole only. The Utilitec timer is very solid timer otherwise.
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
I recommend Aube timer as easiest for 3-way switching.
It replaces either 3-way switch, works for CFL or incandescent, and is a solid Honeywell product like their line of thermostats. Aube timers have internal battery and cannot be exposed to freezing temperatures or extremes of heat.
Note: With 3-way timer, the timer replaces one 3-way switch, and the other 3-way switch remains.
In all cases with 3-way timers, the remaining 3-way switch is rewired slightly to accommodate how the timer works.
Read the manual carefully and look at images. Add a comment for more help with 3-way timers.
Sep 25, 2011 | Hardware & Accessories
Need Aube by Honeywell TI032-3W-5/U instructions
http://waterheatertimer.org/pdf/Aube-TI032.pdf
Manual for Aube T1032
Internal rechargeable battery
7 day programmable timer for halogen, incandescent, florescent
Aube T1032 has 40 Watt mim & 500 Watt maximum (5- 100 watt incandescent bulbs etc)
Buy Aube-1033 for heavy 20Amp 2400 Watt maximum
Replaces single-pole switch or 3-way switch (slight modification needed in 2nd 3-way switch)
Buttons
Oct 12, 2010 | Honeywell Aube by TI0323W5U 7Day...
Lost the instructions T1032-33-34-35 can we get them?
http://waterheatertimer.org/pdf/Aube-T1032-timer.pdf
Aube is a Honeywell product I believe:
The timer seems revolutionary for not requiring a Neutral wire, yet requires no battery either.
Advantage: No more confusing wiring. Simple 7-step programming.
If old switch has 2 wires, the Aube changes to 2-wire application
If old switch is 3-way, the Aube changes to 3-wire application, the only major change is jumper on other 3-way switch
Timer replaces ordinary wall switch:
Timer replaces 3-way switch
Oct 06, 2010 | Aube Technologies Aube 7-Day Programmable...
Need instructions for Aube by Honeywell 7-day programmable timer switch
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
Nov 04, 2009 | Aube Technologies Aube 7-Day Programmable...
Our controle module TH132 A/F/AF goes blank every time the heating systen is supposed to be activated
I have also had the same problem with 2 units. I have been in touch with Aube who say they have identfied a problem with the back unit which they will have fixed in " a few months time". My suggestion would be to contact them for a replacement later on this year
Oct 27, 2009 | Aube Technologies Hardware & Accessories
Aube CT280-2H1C exit pin for humidifiers dont give 24vac
Jan 28, 2009 | Humidifiers
Hardware & Accessories Logo
32 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
