Question about Pool & Spa
My pool pump turns itself off then on again without my interference.
  • 913 Answers
Designed this way
Posted on Dec 02, 2016
Our pool filter keeps turn itself off even if you have it running on manually
I would look closely at the pump motor itself. Without complicating it to much some are 2 stage (mostly the 240v variety) if a relay or other component goes bad and the motor overheats there may be a thermistor or "Temperature Fuse" that shuts the motor off to protect it from damage. This is just a starting point so let us know and good luck
Dec 07, 2016 | Pool & Spa
My pedrollo pump, pumps water for a while and goes off by itself. i have put it off (electric switch) and wait for time say 5min and put it on again. it works for a while and goes off again so i have to do...
it sounds like the pump is tripping the overheat relay. might be time for a new pump. depending on how far the 'tank above' is, you might not have enough pump to push water there.
Jan 02, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Hayward Pool Pump Motor Problem
if it looks like the one pictured it has 2 caps on it both must be good, the start switch might have some trash in the points and can be cleaned with the striker off a match book, be careful not to bend point arms. search your area for your local pool pump motor repair guy..
jay the pool pump whisperer longwood florida
Jun 04, 2012 | AO Smith 1.5 hp 3450rpm 56Y Frame 115/230...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pool & Spa Logo
168 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
