Question about Whirlpool Washing Machines
I have a whirlpool washer model wtw6700tw1 see #cw2273416
    Sergeant:
  • Whirlpool Expert
  • 448 Answers
More info please what is the issue
2 Suggested Answers
  • 1531 Answers
SOURCE: i just got the wtw6700tw1 whirlpool washer. it is
go to www.whirlpool.com click on go to owners center an click on owners manuel and down load it
Posted on Sep 15, 2009
I have a whirlpool washer model wtw6700tw1 see #cw2273416 It's reading Lp and not working at all
sure its not LF that's long fill check water is turned on all the way or change water valves on washer
Dec 02, 2016 | Whirlpool Washing Machines
Whirlpool wtw6700tw1 liquid bleach dispenser will not empty
3 possibilities the hose fell off inside, , the solenoid is bad, the switch is bad.
Jul 14, 2014 | Estate ETW4400VQ Top Load Washer
Whirlpool cabrio wtw6700tw1
You can buy a new pump from partsclinic.com The following link is for the part and a video on how to replace it
http://www.repairclinic.com/PartDetail/Drain-Pump/W10217134/1472275?modelNumber=WTW6700TW1
Oct 13, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
My cabrio wtw6700tw1 does no rinse so the water not drain out of the basin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
Washing Machines Logo
27 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
