Televison & Video Logo
Where can I get a ms 4048 get board for magnum inverter
Vizeo tv no picture
If audio is OK, the fault would be with its back-light inverter. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Tassimo coffee machine
Most power inverters require the vehicle to being running to operate, and make sure it's the correct wattage, if it's a small watt inverter it doesn't have enough power, as a coffee machine is considered higher wattage, hope that answers your question ?
I have a 3000 watt magnum energy sine wave inverter/ charger. It is hooked up to 5 -12 volt glass matt batteries. the charger used to charge in bulk mode @ aprox. 80 amps then absorb charge and then went...
I'm sorry that I can't help you, but if you're in a hurry, you can visit the Magnum website at: http://www.magnumenergy.com/Service/Servicefront.htm and try to find your model's online manual and search troubleshooting advice or you can email customer service at
[email protected] and they should at least be able to lead you in the right direction.
A few questions: Does this problem remain even when there is at least a 10+ watt load on your system? is your Magnum in a hot environment? Does your inverter feel extraordinaryily hot? Have your batteries outlived their lives? Have you cleaned all the connections? Even if they 'look' like they don't need it?
All the best to you.
1helpful
The invicta 4048 is an atomic watch with 4 buttons only. I need to know how to set this watch. Previous experts have refered me to the standard Invicta instructions PDF. The atomic watch is not covered...
The Invicta Atomic 4048 is "discontinued", and Invicta is not very helpful. They do NOT offer an instruction manual for the 4048, because it's discontinued. You can call Invicta at 800-327-7682 then you have to ask for "Melvin" who only works until 1PM eastern time. OR you can do the following:
Hold down the 8 0'clock button until it flashes, select 12hour or 24hour preference, use the button at 4 o'clock to select your time zone (GMT) The watch should reset itself to your GMT time.
1helpful
2answers
Tevion 42 inch lcd flashing standby light and tv will not turn on
If you can checked LCD Inverter Board & Micom Board.Most of Inverter board is defective.
Fan controller does not work! Power Up (TC3J-4048)
It is bad out of the box. either take it back or email whoever sold it to you and get a new fan. You should not have to pay for a new one.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
