SOURCE: Acer 5315-2713 add memory card
OK, In general for the 5315 series, the memory replacement should be roughly the same.
You seem to have an idea what you're doing, so here's a little specifics:
Here's what you see once you get the giant "thermal door" cover
off. To remove the cover, first, remove the four screws. Now carefully
slip a thin tool like a table knife under the edge of the cover where
the indent is and work around towards the front and back of the laptop.
DON'T pry along the side towards the side of the laptop or you'll break
those longer tabs. That's the edge which goes in first when you replace
the cover.
The RAM pops out easily by spreading the clips on either side.
SOURCE: KitchenAid 2671 Mixer always wiggling
I have had the same problem to remove the motor you need to remove the two screws at the back of the motor next the two screws holding on the circuit board (so you can get at the screws around the gearbox ) next remove the cover on the gearbox by removing the four screws and lift off after you have done this you can lift the motor out but remember you still have the wires connected but you can get at the screws to tighten the head down try using lock-tight on the screws
SOURCE: ASUS M300Np won't start - need to reseat RAM but unable to access
my computer will come on for a few seconds and then shut off and it is plugged in
SOURCE: hello does my lynx 455 plus sensors have lights
Not familiar with lynx but every sensor I have seen or heard of has a light. It is the only way to tell when they are pointed correctly at one another.
SOURCE: Hi, I have a Lynx 455
Check the sensors in the doorway. Sounds like they may be misaligned. They need to be pointing at one another to work properly.
