Question about GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control...
Wall Oven JKP30W0M1WW - front control panel overlay bubbles and separates. It did this before it was 1 yr old and they sent me a replacement and now before that part is 1 yr old it is doing it again - faulty part? Or is there some other reason. This time they charged me for the part.
GE is now fixing this problem, no charge. I called about mine, at 866-622-6184 They have the white version already available. A month wait on the black. Then they send out a service tech to install, free to you.
Posted on Feb 07, 2011
Oven beeps with f7 code , replaced display pcb . oven still beeps replaced front touch pad , now cooling fan comes on and after a while oven beeps with no error code . and blower fan button does not work ,...
hello,
(indication of problem)
This error code on a oven indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.comappliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this information helps you.
thank you for using fixya.
Oct 03, 2010 | Jenn-Air Ovens
Error code f3 when oven is started
hello
searspartsdirect.com repairclinic.com
thanks for visiting fixya.
Oct 03, 2010 | Magic Chef Ovens
Oven is not working; Code F1 appears.
hello,
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
repairclinic.com
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourselfer. If you decide to order the part and wish to repair this on your own, follow these steps:
thank you and thanks for using fixya
Oct 03, 2010 | Maytag 30 in. Electric Single Wall Oven...
Getting F1 error codes. What does it mean?
hello,
Aug 28, 2010 | Maytag 30" Built-In Double Electric Wall...
I have a GE JTP70, The Plastic over control panel bubbled up.
Mine did the same thing...and believe me it even looks worse over time....look online it happened to a lot of people....GE won't do anything about it....it is a defect but they won't own up to it......They just want you to keep replacing the part, which cost a fortune. Mine oven cost over $1000 and I am stuck with a nasty looking piece of garbage in my brand new kitchen......can't afford to buy a new one.........I Will NEVER BUY ANOTHER GE PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 19, 2010 | GE JTP70 Electric Single Oven
One of the buttons on my control pad is flat
It depends on if the issue is in the control board itself or just the overlay has become flat.A new control board would be part# WB27T10911 which is about 120.00. The overlay part number is WB27T10968 and retails for approx 85.
To replace either one you would have to remove the control panel and control board. The overlay will be glued to the control board. You could take a heat gun any heat the board up slightly to remove the overlay. Be sure not to let the board get too hot you dont want to damage any of the components on the board. Hope this helps.
Jan 28, 2010 | GE JTP30SMSS Stainless Steel Oven
Bubbles on control panel overlay
If the overlay isn't a protective foil that easily peals off, the hair dryer would only serve to distort it, I don't believe it will cause it to shrink to fit. If it was applied with a 'self-stick' backing, you may be able to puncture the bubbles and press it back down with a hot rag.
Sep 15, 2009 | GE JKP27 Electric Double Oven
Frigidaire FEF369CGSA ramge- replace clock overlay/control labels
Hi Dagmail543
You can only access the old unit by removing it from the back of the panel.Some screws and clips (base at the two sides) The clock is usually secured with screws. - remove old unit replace with new - no peel or scrape usually necessary
Regards
Aug 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
Jan 02, 2009 | Ovens
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
Dec 12, 2008 | KitchenAid Architect Series KEBC107KSS...
GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... Logo
1,368 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
