How can I get 24c mild flow cooling? I don't understand the 4 symbols on the left top button..triangle, ?snowflake (chill?) water drop(dehumidifying?) and open circle ?
Press the 'mode' button on your remote until it says 'cool' or shows a snowflake symbol. Careful that you don't set it to 'heat' mode accidentally if it only has symbols. The 'sun' (heat) mode symbol can look like a snowflake on some of these remotes. Then set the temperature to suit you.
open cover and press the top right button until the snowflake image is selected then adust up and down with arrows buttons top left next to per button.
by my understanding, it is a type of water heater that is inserted into water. and after bringing the water to a boil, it is removed and kept aside in water cool, left to dry and stored away for future use.
the machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
You need to ensure that the LCD displays a sun symbol. If this is not the case this can be corrected by using the button which has triangle, snowflake, sun and raindrop symbol, press until sun is on screen. Then set temperature.
I take the time to help and answer your question so please rate me
Thankyou
Mat
