I want to fix my magicjack so it stop cutting out every time i make a call
My Magic Jack stopped working a while back and I unplugged it and misplaced the adapter. How do I go about purchasing a new one. And how do I check my account?
MagicJack Phone Number
MagicJack phone support
First describe why you are phoning below to find targeted help and save time. If you decide to phone MagicJack:You get a recording, but do get to speak to an actual person. For billing matters only.
17 mins average hold time - call Mon-Sat 10am-7pm EST
MagicJack Support Channels Compared
MagicJack Email Address
Dec 23, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
My magicjack cuts when iam taking to some one
Check your Internet connection is not the problem, then contact magicjack customer service. International VoIP Phone Service Customer Care Support magicJack
Jan 30, 2014 | Computers & Internet
All Magicjack calls I make will disconnect after 5 to 15 minutes. Why?
Check your computer is not set to hibernate or go into screen saver at these times. Magicjack should not cause the cut-off.
Nov 06, 2013 |
My magicjack plus keep cutting me off while in conversation
Most times the problem will be fixed in several ways.....
1. unplug your magicjack, wait 15 sec and plug it back in
2. unplug the magicjack and plug it back into another port
Feb 13, 2012 | Lands Phones
Magicjack error 401
This error usually shows up when magicjack does an update. You will need double check if you can log into if you can then you will need to reinstall the magicjack software and try again. If you cannot log in then there is an update taking place and you will need to wait it out.
Hope this helps
Mar 08, 2011 | Computers & Internet
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
After 3 months my MagicJack stopped working. I have this same problem with 3 different MagicJack devices: after dialing a few numbers successfully, when I dial the next number I hear only 1 or 2 rings then...
Likewise I had the same problem, spent 3 days and on hold for 2 hours at a time, told the tech who was doing a live link into my computer suddenly went on break, then was gone for the day...their TECHNICAL SUPPORT IS A NIGHTMARE...and no, we still do not have a solution to our phone and went through alllllll the same gyrations!
Mar 14, 2009 | Lands Phones
MagicJack VOIP sound cuts in and out
MJ ran fine for me from July 2008 to October 2009, when choppiness and cutouts started and continue to today. This is a MJ network problem, there is no fix in your own computer, as I have tried everything - computers, internet speeds, headset with phones unplugged, other Magicjacks. The MJ servers have just become overloaded. MJ is dead.
Nov 05, 2008 | Lands Phones
I just bought a new computer, a mac, and bought the magic jack hoping to have a reliable home phone family and friends could call me on.  But ever since I hooked it up(which was easy to do) my calls cut in and out every call I made-over and over again.  Every call.  Not just here and there.  Anyways, I was reading other people's complaints and it seems that a lot of other people are experiencing this as well. I have Verizon DSL at the midgrade speed-something like 3.0 mps.  Fast enough for MagicJack.  What I was doing was running the supplied router that came with the Verizon package which included a built-in wireless router to run my computer with without the cables(of course).  So I did a lot of research, didn't even call customer support, and someone out there gave me the solution I needed without calling. That person suggested that I not use the wireless and hardwire it instead using an ethernet cable.  Granted, this does have its drawbacks, but ever since I did that every call has been perfect.  So, some of you may be able to get away with cheap home phone service with reliability just by using the ethernet cable instead of the wireless router.  Heck, if its close enough, keep a spare ethernet cable close by, unplugged from your computer(still using the wireless) and when a call does come, quickly hook in the ethernet cable for a near perfect call with no cutting in and out problems.  This is a solution that worked for me and maybe for some of you out there too.  Good luck.
Nov 05, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
