Question about Toshiba Toshbia E-Studio 305se
I have a Toshiba 305se, and have, LT (paper empty) error, tray1, don't print, said..add paper but tray is full.
  • 2072 Answers
SOURCE: says add paper to large tray even though it is full
Depending on which large capacity feeder you have.
If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
Posted on Feb 12, 2009
SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Posted on Feb 18, 2009
  • 92 Answers
SOURCE: toshiba dp6750 paper trays not working
check connectors on pcb make sure everything is plugged in
Posted on Jun 28, 2009
  • 51 Answers
SOURCE: My Toshiba e studio 28 keeps saying to Add Paper
Tray motor is bad or gearing has fallen out of place. Could also be paper present sensor in the machine above the tray.
Posted on Apr 06, 2010
SOURCE: My Toshiba estudio 352 isn't
How stop or reset year and date and tim
Posted on May 19, 2011
Paper won't pull out of tray1- even when full
Jul 02, 2014 | Lexmark Office Equipment & Supplies
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Procedure to activate auto Tray switching in hp laserjet 4100
Okay, do you mean "Tray Linking". The process where, for example, if Tray1 goes to an empty condition, tray2 so the print job runs uninterrupted?
Or do you mean that you want Tray1 to print 6 or so pages and then switch to tray two because you need a different style of paper.
Tray Linking - you use the printer setup to activate.
Switch Trays - Usually controlled by printer escape codes.
If you create a "Print To File" off of the driver page, and send it to me at don.farr@hotmail .com I can look at the file and see what you are doing.
Dec 08, 2009 | Office Equipment & Supplies
Dear Sir, We have a Fujixerox Docuprint C2100 and we have a message error about our tray1. We try to print using tray1 (have paper inside) but the printer request paper.
I would remove the tray from the machine and all paper from that tray. Then turn it over and make sure and make sure that the paper slides are working correctly. The machine doesn't actually detect the paper just the fact that you have the paper slides up against it. So after you have put the tray back in the machine make sure the paper slides are firm up against the paper and it should be fine.
Also, while the tray is out of the machine make sure there is nothing in behind the tray blocking the sensors.
Jan 19, 2009 | Xerox Phaser 8500/DN Printer
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Oct 14, 2008 | Kyocera Office Equipment & Supplies
Toshiba Toshbia E-Studio 305se Logo
111 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
