Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do I tighten the mower belt on a lt1000?
Tighten mower belt on lt1000
    President:
  • 1,273 Answers
It is kept tight by a tensioning pully. If it is loose, replace it.
regards, --W/D--
Posted on Jul 21, 2009
How do you tighten or loosen a belt on lawn boy self propel mower? Where is the tension pulley bolt located to tighten?
most self propelled mowers engage an arm to put the gearbox into drive so it may not be a case of loosening the drive belt
May 06, 2015 | Garden
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
How to tighten a craftsman LT1000 belt ?
There is an idler pulley that engages the mower deck and tightens the belt automatically on your model. Check to make sure the belt is routed correctly, return spring is in place and that your cable is operating smoothly.
Jul 19, 2014 | Craftsman Garden
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you tighten the belt on a 12.5 hp steel sleeve murray riding mower?
you cant tighten the belt if everything is working . if belt is slipping its either the wrong belt or its stretched and will need a new one.
Oct 20, 2009 | Garden
Tighten belts on my Yard machine ride on lawn mower
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Sep 12, 2009 | Mtd Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,073 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
