I am looking for the value of resistors 85 and 86
    Master:
  • 501 Answers
Search it on line.....not hard to do......
Posted on Dec 02, 2016
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Posted on Mar 12, 2012
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
WHAT IS THE VALUE OF RESISTOR R10 IN THE CIRCUIT BOARD?
Look at the color bands, they will determine the value. Last band color is the precision value of the resistor. You can find the color band values on many websites. The size of it tells you the wattage raring.
Mar 02, 2015 | Compaq CV 7500 17" CRT Monitor
Motor Joy
Hey boss. Just follow this guide and replace with a resistor that matches the value and tolerance. You have a 5 Band resistor, follow the guild and you should be good. Click here for a chart to help you identify the values.
Jul 06, 2013 | Car Audio & Video
Mar 12, 2012 | Televison & Video
Resistors value was burned
Your can still get the value of the resistor by testing the half and one lead of the resistor and then plus it to the other side. So your will see the resistance. Then look at the standard chart will is near to that value.
Sep 24, 2011 | Sanyo Televison & Video
I need the value of resistor connected in the Ac line, what value is it?
Hello
Your post is not clear. It doesn't specify tthe brand name and model number of the TV. Anyway I hopes that you are in need of the value of series resistor [ a wirewound one usually cement type] I thinks and post this solution.
The value usually will be between 3.3Ohms to 4.7Ohms [ 7W] wirewound type resistor.
If this resistor has opened, look into its power regulator side for any defects, before replacing it with an other one.
OK.
Jan 19, 2011 | Televison & Video
RK46 BURNT CANNOT SEE COLORS ONLY 2 STRIPS DARK AND 2 STRIPS LIGHT. WHAT IS THE OHM VALUE AND DO I INSTAL GOLD STRIPS TOWARDS IC OR AWAY. HATACHI 43FWX20B DP24 JOE
rk46 is 1.8 ohm resistor---rk54 is the same value, rk 62 is 2.2, and Rk 42 is 3.3 ohm. It does not matter which direction it is installed---it is a resistor
If you have any questions feel free to let me know.
SD TECH
Oct 08, 2009 | Televison & Video
Burned resistor... no clue what is its value
brYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Aug 31, 2008 | AOC 4 Vn 14" CRT Monitor
Replacing Convergence IC's, I found a bad resistor needing replacment
They are both 1.8 ohm 1watt fusible resistors. Metal film 5% 1.8 ohm 1watt will substitue them
Aug 08, 2008 | Toshiba 50H71 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
