Question about Tablets & eReaders
How can I get a signal on my tablet - Tablets & eReaders
I have a Samsung 10" tablet. I am having trouble connecting my cannon PRINTER c/- Wi-Fi. Works sometimes other times takes a long time. Can you help
Sounds like there's too much noise in the signal. This is almost always caused by either too far a distance between the router and the tablet, or the type of construction the signal has to pass through.
As the signal weakens, it introduces drop-outs of signal, (called noise) and forces the table and router to restart the connection procedure all over again. Do this enough and you begin to notice the delay in making a connection.
Simplest way to isolate this, is to try to make a connection with the tablet while you are in the same room with the router. If it connects immediately, its the deteriorating signal quality that's causing the delay.
Couple of fixes, one is to relocate the router to a higher position so it had less metal surrounding or other disruptive factors, or into a different, closer location where the table is being used).
Another possibility in large homes is to add a wireless relay into the system. This receives the signal and rebroadcasts it. (It extends the coverage of the original signal). This can be mounter anywhere where it can receive a good signal from the router and still cut the distance to the tablet in half.
One other option is to buy a new router that has a better signal or operates in a new, higher band and allows faster communications. But construction, the amount of stuff between you and the router will still degrade the signal.
I would try relocating the router to a different position, perhaps higher in the room it's currently in, first.
Feb 09, 2018 | Samsung Tablets & eReaders
Wifi connection-kindle fire cannot find wifi signal - 3 ft away
The wifi connection may be turned off. I just had that experience on my Kindle. Once I turned it on, my next book downloaded.
Oct 07, 2016 | Amazon Kindle Fire HD 6 Tablet - 16GB
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
I keep losing wifi signal why?
Because the wifi signal isn't strong enough or because your tablet is electronically faulty.
Dec 30, 2015 | Tablets & eReaders
My tablet,so i can get wifi and a network i had it working before on my tablet
hello sir,
something wrong with the tablet settings then, please check it and get it back to how it was when you got the wifi and the network signal
also, make sure that the wifi signal exist, by another phone, or tablet, so you be sure about it
if the settings are okay, and the wifi is ok, then its the wifi and network chip at the tablet
good luck
Oct 24, 2015 | Amazon Kindle Fire HD
Now on a acer tablet
Strong is relative to your position and where the signal is coming from. If you don't have a wireless router in your location then the signal has to go through walls etc. either way it is not your wireless signal from what I gather from your post.
Apr 10, 2015 | Acer Tablets & eReaders
Weak wfi signal
Did you check in wifi settings and make sure they are both picking up your wifi and not a neighbors?
Nov 30, 2013 | RCA 7 DUAL TABLET DVD SYSTEM
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
