Question about LG Televison & Video
Lg tv burn power ic - LG Televison & Video
    Top Expert:
  • LG Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts. You can get details there.
Posted on Dec 02, 2016
Vizio 55 inch TV "Vizio E550I-B2" is Darker on the left viewing side, replaced the Power Supply board. And the Screen is still dark on the left side. Any suggestions?
It is a common problem for this TV, it uses a Sharp LED display panel. The problem is the data buffer IC inside the panel ether shorted, or burned open.
Vizio offers a extended exchange warranty if you have the original sale slip.
For more information, you may contact Vizio directly.
Apr 24, 2017 | Vizio Televison & Video
LG 42' plasma tv
Based on the symptom it seems like you have a problem either with capacitors or mosfet ic's burned on power supply. I will open up the tv and closely inspect for any burned/damaged component. (google burned capacitors for you to have an idea on how they might look like). If you find any you can either replace the component or you could also replace the whole circuit board. The specific part number must be print out on the board itself. You need this number to order it from any part distributor.
Good Luck!
www.silvertvcomputer.com
Tv Repair Chicago Gold Coast Tv Repair West Town Tv Repair
Jun 08, 2014 | LG 42LC2D 42 in. LCD HDTV
Lg tv
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 17, 2013 | LG Televison & Video
Hello, when I turn on my LG 42 Plasma TV, triggered switches and burned out the fuse and power cable to the TV
hello, there's a possibility that the power supply has burn't out or a circuit board connected to the power supply
regardsshaun
May 11, 2012 | LG 42LB2R 42 in. LCD HDTV
I need sheme for YPLM-M003B of LG L1717S-SN.IC in primar of power supply is burned.
I have this power board,LAF0001 pwm is the only use IC.
20 pin Inverter IC labeled (0zl68GN VKo257 5T 0647B1)
and 2 8 pin dip IC
Sep 10, 2011 | Televison & Video
The 37 " lg tv
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will helpout....
May 14, 2011 | LG Televison & Video
LG TV RT29FC85VW 29" woofer not working
Check the Woofer for continuity and also with an external amplifier.
if there is no issues then the sub-woofer power amp IC can be faulty.
Check the main voltage to the IC, if not present the power section must be traced for a line break, fusible link.
If there is power , then test for input signal to the IC. If so the IC can be the supect.
Oct 28, 2010 | LG Televison & Video
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
LG 42PC3RV module LGEPDP burned hybrid IC
If the buffer drive bds. were replaced along with the ysus and zsus and this problem occured it is definately and defective pdp.
Nov 29, 2007 | LG 42PC3DV 42 in. Plasma EDTV
Televison & Video Logo
Computer Repairing
Computer Repairing
