Question about Roper REX4634KQ Electric Dryer
Dryer is running fine just not getting hot
everythings running fine but it's not getting hot, and usually I can look over the dryer and see the red light( which i figure is the heating element) on the back where its getting hot and its not coming on.
    President:
  • 1,776 Answers
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Posted on Jul 20, 2009
Which wire do i test to see if my kitchenaid dryer motor is getting power
You may have to run a cycle or 'set' the dryer (dial=ready) as these wires are not continuously 'hot'. Although there are usually a white, black(or red) and ground wire. Black or red is 'hot" white is "neutral' .
I hope this helps
Jun 09, 2014 | Kenmore 63942 Dryer
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Everything is connected and running (cord, gas line, etc,). Dryer works fine, but the air is not getting hot...why is that?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
[pp[p[
Aug 17, 2011 | Maytag Dryers
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
The dryer is turning, but it isnt getting hot. I put a new cord on it!
Is this dryer electric or gas heated...if electric...did you wire it properly...electric dryers use 220 VAC and have a very large plug on them...usually there is a black, red. white, and green wire...the white is neutral, the green is ground and the red,black are the L1 and L2 hot leads...these need to be wired to the 2 hot terminals in order for the dryer to function properly
Dec 30, 2010 | Roper Dryers
Dryer will not get hot,but everything else works
Hi. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer or on the actual heater chamber or blower housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Aug 24, 2010 | GE Profile DPSB620ECWW Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Kenmore Clothes Dryer Model 67902790 has no heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.(Thermal cut-off)
Aug 24, 2009 | Kenmore 62882 Electric Dryer
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Roper REX4634KQ Electric Dryer Logo
645 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
