Question about Garden
What size brushes do you use in a Trimrite 900 weed eater?
    Top Expert:
  • Garden Master
  • 45,422 Answers
Possibly the manufacturer will know , we do not
Posted on Dec 02, 2016
How to replace carbon motor brushes on a weed eater
are you sure they are replaceable brushes if they are they should just unscrew in the holder .
Aug 06, 2015 | Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the purpose of having two different size fuel lines in the fuel tank on a weed eater trimmer ?
Weed eaters have a diaphram operated carburetor instead of the float operated ones on a lawnmower. The bigger one is the fuel to the carburetor and the little one is the return to the tank from the carburetor.
Jul 27, 2011 | Garden
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed Eater ELECTRIC Lawn Edger sseized up. If I
If it is seizing up it is probably not worth fixing,but there is a chance that you just need to change the brushes.You can usually pull these out pretty easially,and have a look at them.If they are all eaten away try replacing them.Again though if it is actually locking the shaft,and pulling the brushes out does not free it up you may have to just toss it.
Jun 06, 2009 | Garden
No Gas to Primer Bulb
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
May 21, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need motor brush
Try a power tool repair shop
Try an electric motor repair shop
Try to find brushes that have the same length spring, same size spring. If they are a little big, they can be made smaller by dragging them on a flat file 'till they fit nicely.
Apr 28, 2009 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
