Question about Canon Office Equipment & Supplies
I have cannon c5051.it is appearing a code E000075-0103. Pls tell me how to fix it.
What is error code E000003-0002 on cannon irc 3380i
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Apr 21, 2015 | Cannon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Canon c5051
delete the printer in devices and printers, then re install it should work ok.
Jan 28, 2014 | Office Equipment & Supplies
Canon c5051 gets stuck on processing job
Reinstall the printer driver. Upgrada the firmware, clear mcon....hope it helps
Sep 25, 2013 | Canon imageRUNNER ADVANCE C5051
How to printer conect to other machin lan thorow ? pls tell me
www.networkmagic.com is a free program that you can download and allows you to see your whole network and printers and diagnose if a printer will not print or not and offers solutions.
Jul 24, 2012 | Cannon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Feb 21, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
46 people viewed this question
old marine
old marine
