Question about Dishwashers
My dishwasher CDI 454. I can't start it again because E 4 pops up in count down area . How to correct?
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Posted on Apr 14, 2006
Dishwasher control panel problem?
what is your model number is then we can get started then
Jan 04, 2013 | Dishwashers
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Trying to start bike but just turning over but not starting .checked spark plugs but no spark
Make sure that the spark plugs have the correct gap : 0.7-0.8mm or 0.028-0.031in
If there is no spark at any of the 4 plugs I would suspect the cdi box 1st as it effects all 4 cylinders. I suspect a wire or connection has come undone and would retrace some steps in that area for a lose or bad connection.
Jun 01, 2010 | 1999 Suzuki GSX 600 F (Katana)
My 1995 yamaha vmax motorcycle starts fine. when it warms up after a bit it shuts down. the shop is puzzled. they said that all 4 coils test out fine but when it is warm they all 4 just stop. no spark goes...
have them test the cdi box. it is your electronic controler for your ingnition timeing. it could be getting hot and shuting down. when it shuts down. the can take a wire from the negative side of the coil and ground it to the frame touching it and letting go of it instintly and if it sparks its not the coils it will be the cdi box or something to do with the electronic pickups in the motor that gives the signal to the cdi. that it is the correct time to trigger firing. hope this helps out.
Mar 10, 2010 | 1995 Yamaha XJR 1200
Machine not working showing E4 fault candy cdi 454
something is stuck in the filter (big olive, valve from baby bottle...) so the water can't get out. Clean filter, then make sure all water is out of the machine (we sucked it out ourselves with a tube and a bucket, ieuw..). Then wait a couple of days: the machine/wires/etc. needs to get dry before you can use it again! Try to turn it on after two or three days. Do not call an expert before you've tried this, it will save you a lot of money... (wish I'd done it...)
Jan 12, 2010 | Dishwashers
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Nov 20, 2007 | Bosch SHU5315UC Dishwasher
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
