Question about Morphy Richards Kitchen Appliances - Others
Is there someone that can send me through the post an instruction booklet for a Morphy Richards breadmaker series 48220.fastbake 48230
SOURCE: I am looking for the instruction leaflet for my
download the manual from the link below:
after u click on download PDF manual a small window pops up asking u to enter four no.s being shown....enter those four no.s and get going............
thanks for using FixYa
Posted on Mar 22, 2009
SOURCE: can i download instructions to use a morphy
morphy richards fastbake bread maker 48280
Posted on Dec 16, 2009
  • 15935 Answers
SOURCE: the rubber gasket on the
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
  • 1739 Answers
SOURCE: were can i get a morphy richards fastbake
The Instruction Book for the Morphy Richards 48280 FastBake Bread Machine can be found here:
Is the 20002509 another model number or a serial number?
Sorry someone has not responded sooner.
Posted on Jun 20, 2011
  • 1739 Answers
SOURCE: i have been given a morphy richards breadmaker model 48280 and need instructions please
The Instruction Booklet for your Morphy Richard 48280 Fastbake Cooltouch Breadmaker may be downloaded from the following link:
Posted on Dec 17, 2011
Bread maker morphy richards 48270 manual
I have a copy of the morphy richards manual for what they call "the compact breadmaker" but they don't show a model #, contact me if you want the one I have for sale
Oct 23, 2011 | Morphy Richards 48280 FastBake Bread...
Need a manual for fastbake bread maker
Mar 03, 2011 | Morphy Richards 48280 FastBake Bread...
Where can i get Morphy Richards 48280 FastBake Bread Machine instruction manual
Feb 06, 2011 | Morphy Richards 48280 FastBake Bread...
Where to buy a insturtion booklet and recipi book
goto the morphy richards web site and down load it direc.t or if you live in the uk get a argos catalouge find morphy richards in the contact numbers in the back ring them and they will send you one
Jan 15, 2011 | Morphy Richards 48280 FastBake Bread...
Were can i get a morphy richards fastbake instruction manual modal number 20002509
Jan 14, 2011 | Morphy Richards 48280 FastBake Bread...
Morphy richards breadmaker 48268 manual
You can download and print the instruction manual for Morphy Richards breadmaker 48268 in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 19, 2010 | Morphy Richards 48280 FastBake Bread...
Lost manual for Morphy Richards Fastbake
You can download the manual at
Jun 26, 2010 | Morphy Richards 48280 FastBake Bread...
Kitchen Appliances - Others Logo
71 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
