SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
SOURCE: MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
SOURCE: Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
SOURCE: my lg intellowave microwave will not work
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
You can download many LG service manuals here, but strangely, they do not have part numbers in them.
You can order parts from
Encompass here
or you can call them toll-free at
866-779-5835.
If you don't find your model's service manual or need more help, feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so with a one-year
guarantee.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Here is a link to what I believe is your issue.........it just took me a long time to extract info from the owner on the failure. [FIXED] Maytag Neptune, Timer Problem
Maybe a FIXYA tech can jump in and add what they think might be the issue and a troubleshooting/repair path to follow.
You can make the machine last for a long time............way beyond the 3.5 yr. to 6 yr. point of most failures.........but each owner has to decide their course of action.
I go by dh1200s on most washer DIY forums including this forum.
