My techika tv keps going back o stadby can someone tell me whats wrong with it
My techika tv was working ok the following day I went to turn it on an the blue light came on an went right back to stand by and has been doing this since
  • Televison & ... Master
  • 6,694 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 02, 2016
My tv screen went completely black
If its worth fixing depends on age of set and what it cost.
The place to begin is someone needs to open the set and check a few things------the click is a mechanical relay coming on and likely going right back off.
The problem could be minor or major.
You might want to begin by calling local shops and see what they charge for an estimate of repairing----should tell you if you want to proceed or move on and replace this set.
Mar 16, 2012 | Sanyo HT32546 TV
2001 Honda Civic Key Green light keep flashing in the dashboard
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 08, 2012 | 2001 Honda Civic
2001 Honda Civic, key green light keep flashing and the car wont start
This will help.
Thanks.
Feb 08, 2012 | 1998 Honda Civic
Samsung LE32R7 Picture come on then goes straigt off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 26, 2017 | Samsung LE32R72B 32 in. HD-Ready LCD...
My 6 to 7 yr old television suddenly went dead
There is a board that manages the power going into your tv I would check around with local mom and pop tv reapir shops. The board is not expensive its the labor I am not sure where you live but I am sure there are local techs that work on flat panel tv's. They are pretty affordable these days. Most flat panel tv's are rated for 60,000 hrs as there life span. Hope that helps
Mar 25, 2009 | Panasonic Televison & Video
My 52' vizio will not turn on
It's due for surgery to repair the power supply and or main board. One way or another it is defective but let's try the following couple steps as a work around (works for me)
Try this:
1- press power ON
2- wait 20 seconds
3- press power OFF
4- wait 20 seconds
5- press power ON.
Does it start the *second time* with the timings indicated above or never?
Feb 13, 2009 | Vizio L32 32 in. LCD HDTV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Ge model 46gw945
NEED SOME TECH EXPERIENCE ON THIS--- UNPLUG THE TV,,,I REPEAT ,UN PLUG THE TV FROM AC---TAKE THE BACK OFF--CHASE
THE CORD THAT GOES INTO TV AND YOU SHOULD SEE A SMALL 5 AMP FUSE IN A HOLDER,,CHECK TO SEE IS IT;S BLOWN--IF SO ,,REPLACE IT WITH"""THE SAME FUSE""""""""""" ,,AFTER REPLACING --REPLACE BACK OF SET ,,PLUG IN AND TURN POWER ON,,IF IT STILL DOES NOT COME ON --CALL A SERVICER,,,,,IF IT WORKS ,,,,,,,,,,,,,YOU OWE ME 35.00--HA!!!!!!!!!1
Feb 09, 2008 | GE 46GW945 46" Rear Projection Television
Rca 32v434t
went in the menu and blocked the panel buttons on accident
Oct 13, 2007 | RCA 32V550T 32" TV
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
Televison & Video Logo
Top Televison & Video Experts
