Question about Toys
Can i download and install LeapFrog Connect from a PS3 with WIFI
Forgot code for the leap frog and it wont let me get wifi
Wi-Fi Troubleshooting - LeapFrog
www.leapfrog.com > ... > LeapPad Ultra & Ultra XDi
LeapFrog EnterprisesPlease note: If you have gone through all the available troubleshooting on this page and still cannot connect to Wi-Fi, you can purchase and sync apps to your ...
LeapFrog Customer Support ' Help & Support For LeapFrog ...
www.leapfrog.com/en-us/support
LeapFrog EnterprisesKid-Proof LeapPad Warranty ... LeapPad Ultra Getting Started Video ... I forgot the Parent Lock code for LeapTV, how can I access Parent Settings? What is the ...
LeapPad Wi-Fi Support: Setup - LeapFrog
www.leapfrog.com > ... > Wi-Fi Troubleshooting
LeapFrog EnterprisesIf you need to set up your LeapPad's Wi-Fi connection, please click on of the links ... Click here to view the step-by-step instructions on changing the current Wi-Fi ...
LeapPad Ultra - Parent Settings - LeapFrog
Feb 03, 2016 | Toys
What is the 4 digit code to the leapfrog ultra
Hi, Please Call the LeapFrog Help Line on 01702 200244 and they will reset this for you or you can e mail them @ support@leapfrogstore.co.uk
Sep 06, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
Won't set up
Try turning off your wifi and skip the wifi setup and create a profile. Then install Leapfrog connect on PC and update the Leappad. This should then resolve your wifi connection issue. It worked for me when I had the same issue today.
Dec 25, 2013 | LeapFrog Leappad Plus Writing
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 | Toys
Having and issue with the audio download on the Leapfrog Tag system. I have Leapfrog Connect installed on my Mac. Audio for books previously downloaded and newly downloaded are not able to be put on pen. I...
Just got this from LeapFrog. Worked for me, although it toook a couple of attempts.
For Macs:
Please try downloading and running this tool and connect the Tag Reader when prompted:
http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
For Windows machines:
1. Close the LeapFrog Connect application.
2. Double-click on this link http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe then click "Run."
3. Click "Unzip" to extract the files.
(You will be asked for a location to save the files. Save them to your Desktop or to another folder that you can easily find.)
4. After the files are extracted, find the "LeapFrogTagFixTool" folder on your Desktop (or where you saved the extracted files).
5. Open the folder and double-click the "TagFixTool.exe" file to open the LeapFrog Tag Repair Utility program.
6. Connect your Tag Reader to the computer. (Make sure your toy is powered on.)
7. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
8. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Jul 26, 2012 | Toys
There was a problem when I downloaded my free game onto my brand new leapster - and now I don't have it on my leapster and I can't choose it again to download
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
But you have to make sure your Leapster 2 have SD Card and your Leapster 2 can connect to PC using Leapfrog connect. Try to uninstall and re-install the LeapFrog Connect and wait until it finish configuring and updated the software both on the PC and the console, It may takes 10-20 mins for it to complete updating.
One more thing, you have to make sure that you get latest LeapFrog Connect software from LeapFrog website instead of installing it from supplied CD.
Jun 29, 2011 | LeapFrog Leapster 2 Learning System
I have just brought a leapster 2 . the download says it is syncing but then does not show on the handheld. just says your downloads have a problem
You need to re-connect your Leapster 2 to your PC. You have to make sure that the software is already updated both in the PC and in the console. Try to uninstall and re-install the LeapFrog Connect and wait until the software has been configured and update automatically which is until you see the status in LeapFrog Connect screen is "connected". You need to wait at least 10-20 mins for it to be completed I'm afraid.
One more thing, make sure you get the latest LeapFrog Connect Software from LeapFrog website instead of installing it from the supplied CD.
BTW, you can get more downloadable games for your Leapster 2 here:
Jun 27, 2011 | LeapFrog Leapster 2 Learning System
Leapstar turns on but when you go to sleet name on screen it nor working it displays anmed but will no proceed when using pen to tap screen
Jun 26, 2011 | Leapster 2
We just bought a leapster 2 and the starter game syncs but does not show on the device
Jun 26, 2011 | LeapFrog Leapster 2 Learning System
Problem with didj
QUICK Summary:
- Download and install "Leapfrog Connect" manually.
- Wipe/reset your DIDJ (maybe...)
- Install the free game.
LONG Summary:
Like most people here on the forums and question boards, the didj hung or failed to download the update: "Download failed. Please try again."
I found that the .EXE from the CD, created a folder in the C drive "C:\Program Files\LeapFrog\log", where the file name was "Sniffer_*date*_*time*.log" Example: Sniffer_090102_1916.log
In this log file, there were two references to the remote files it had to download (in the display window, it says 101 Mb. So the two files below add up to about that much):
http://download.leapfrog.com/leapfrogconnect/PC/didj/DidjPlugin.exe (78Mbs)
http://download.leapfrog.com/leapfrogconnect/PC/UPCInstaller.exe (25 Mbs)
The DidjPlugin.exe is the "Leapfrog Connect" installer, while "UPCInstaller.exe" is the free Jetpack Heroes game.
I cancelled the hung or timed out program launched from the CD, rebooted the PC, and then proceeded to download these two files manually.
After downloading these two files, I double-clicked each one. There was no dialog box or confirmation or license agreement page, destination folder, etc, etc, etc. This was a 'silent' installation, with
no prompts (save for the Windows security prompt: "Are you sure you want to run ...exe?"
I then proceeded to wipe the handheld (because it was stuck on "Downloading Update, please wait...).
Launch Leapfrog Connect:
1) Press the "Ctrl + Shift + R" keys in sequence and hold them down.
2) This should open a window that says "Connect the device you would like to reset".
3) Connect the Didj.
4) Eject the Didj when done.
5) Recreate your player profiles on the Didj and connect again.
I could be wrong, but wiping the didj did not erase the free game. I don't remember, but there was a point to sync the didj and then the game was there... Anyways...
After restarting the didj and creating a new profile, connecting to Leapfrog Connect, the didj should be good to go.
I do have a couple questions:
Why only have a small 5Mb self-extracting installer on the CD? Why not include the larger (75-78Mb) "Leapfrog Connect" on the CD?
Why not have the free game ALREADY installed on the didj? That way, when it comes out of the box brand new, you get to start playing right away...
Thomas
My (kids) PC specs: AMD Duron 1.2 Ghz, 768Mb RAM*
Windows XP, Service Pack 3
Dec 27, 2008 | LeapFrog Custom Learning Case
Toys Logo
120 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
