Question about Drills
On a doosan z290smy the parts catcher retreats before the spindle gets to it. I canno seem to synchronise the right hand chuck with the parts catcher to actually catch the parts
    Top Expert:
  • 50,270 Answers
You need to contact the MANUFACTURER, we have no idea what you have .
Posted on Dec 02, 2016
Looking for a Milwaukee 48-66-1381 chuck kit with a 38-50-5075 spindle.
sure the age of the tool may have parts discontinued or superseded
this is a Milwaukee chuck kit you can buy
and a spindle on sale
try this Milwaukee parts supplier for a part or dimensions of the spindle/chuck you need
Milwaukee 1670 1 SER 472D Single Speed Hole Hawg Drill Parts 26309591-1jfwbypa2loxnuc0fythdbff-4-0.jpg
Oct 13, 2016 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
I need to remove the jakobs chuck from my makita 2030 hammer drill
Open the chuck fully and remove the set screw inside it. The screw has left handed threads and is most likely lock-tited in so get a firm grip on it and turn it clockwise to remove it. The chuck is right threaded but put on very tight. The best way to losen it is to lock the short leg of a 1/2-inch allen wrench firmly in the chuck so you can hit the long leg with a hammer. If the spindle below the chuck has flat spots for a wrench, lock the wrench in a vice and put the spindle in it so you can hit the allen wrench hard enough to break the chuck free. When you put a chuck back on use a drop of lock-tite on the spindle and screw threads and turn them on as tight as you can.
Nov 06, 2012 | Drills
Fleetwood 50 drill press chuck connects to the spindle how?
The chuck on 99% of the drill presses is just a press fit. The end of the spindle where the chuck goes on is slightly tapered to hold it on. Make sure the end of the spindle and inside surface of the chuck are very clean. With the motor off, raise the table high enough so you can still get the chuck on the spindle then turn the handle to lower the chuck against the table and press it firmly against the table to wedge the spindle in the chuck. There shouldn't be any need for anything more than this.
Apr 10, 2012 | Drills
How do I remove drill bit?
Your drill uses a key less chuck (the part that holds the drill bit). Grab the black spindle just below the drill bit and turn it clockwise when facing the drill from the back. Some drills have a locking chuck and only need to turn with one hand. Other drills don't have this option and use a 2 piece chuck. If it looks like there are 2 parts to the spindle, you will need to hold the the back part with one hand while turning the front part with the other hand.
Hope you find this useful
Mr Tin Man
Dec 29, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
I have a Guardina Power 5 speed heavy duty drill press, model number DP-MINI 1/2 inch chuck. The chuck will not stay on the spindle. There doesn't seem to be any set screw, threads or any type of method...
The chuck is held in by the tapered shaft and friction. Make sure the tapered shaft on the chuck is clean with no burrs. Do the same for the socket side in the spindle. Swing the table out of the way and set a wood block under the chuck. Bring the spindle/chuck down into the block quite firmly which should lock the two tapered parts together. Hope this helps as it worked on my drill press!
Nov 19, 2010 | Garden
The chuck came unscrewed from the spindle assembly
yes it can, what you need to do is lock the chuck as tight as you can and then replace the chuck retaining screw which you should be able to find locally, it is a left hand thread.
Apr 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have dw980 cordless handrill dis assemble because is not running/operate when i squis/press the trigger. and when i put it back assemble it its works now but i have 4 pcs of small pin i forgot where to...
Sounds like they could be the pins from the front of thh gearbox/clutch area. Can you turn the chuck/spindle fully by hand when the trigger isn't being pressed? If so then these are the pins that help to lock the spindle for tightening/releasing the chuck. You wil need to take it all apart again I'm afraid as I'm pretty sure you won't be able to get them back in the right place from the chuck end. They sit between the gearbox output plate and chuck spindle plate (both parts should be a sort of 'bow tie' shape) and they jsut sit independetly in there, two each side.
Feb 10, 2010 | Dewalt Drills
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
Jan 27, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
How do i remove the chuck from the Makita 12v 6227D
There is a left handed screw down at the bottom of the chuck. I believe it is a flathead screw. You need to make sure you are in the lowest gear and turn that screw clockwise. It seems odd, but turning to the right will loosen the chuck screw. Once the chuck screw is removed then you need to remove the chuck from the spindle. Remove the chuck like a regular screw. It has regular threads and should be removed by turning it counterclockwise. Good luck
Sep 07, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Drills Logo
141 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
