Question about The Watches
Does the pendulum have anything to do with keeping time ?
  • The Master
  • 1,917 Answers
They were all important once, until about 1930, but are no longer used for precise timekeeping, just decoration.
The property of a pendulum which made it so is that, for a frictionless pivot and a massless rod with a relatively massive bob on the end, the swing period depends only on the length of the pendulum. Thus designs focussed on those factors.
In practice even the expansion of metal parts due to the heat of the day caused errors, and they could not be used in vehicles or boats. The search went on.
Posted on Dec 02, 2016
What causes the pendulum to seems out of balance?
try moving the whole clock one side or another so the pendulum runs better
Sep 09, 2017 | The Watches
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 | The Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
My wall clock runs about 10 min utes fast per 24 hours. I has a pendulum with an ajustable screw at the bottom. Can I turn this screw to adjust the running time. If so, which way (shorten or lengthen)?
You have to lengthen pendulum as this will make watch tick slower. Can not say for how much as for every particular clock there are different adjustments.
Do it bit-by-bit unscrewing the screw thus lowering the bob. Observe time keeping day-by-day and eventually you will reach the right length of the pendulum for precise timekeeping.
Rate me, please.
Aug 21, 2009 | Watches
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 | Watches
I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Mar 23, 2009 | Watches
Watches Logo
22 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
