Question about Lands Phones
I am unable to make a call, message after dialing: conditional call forwarding active.
4 Suggested Answers
  • 821 Answers
SOURCE: Trying to dial out gives message 'Conditional
hello,it could be a network problem from your service provider,so you will need to contact them to find out what the problem is,or you can as well scroll through your setting to se if your outgoing calls are not being barred.
please kindly rate the solution if it's helpful,
take care.
Posted on Jun 06, 2010
  • 37 Answers
SOURCE: I'm unable to call anyone
Go to your settings on the phone and try disabling call forwarding.
Posted on Sep 17, 2011
  • 3 Answers
SOURCE: Tone And Message
how active all call diverting for my phone.
Posted on Jun 23, 2013
How to Transferring a call or call forwarding ?
not sure if this is what you are asking....To activate this feature:
  1. Listen for a dial tone, and press .
  2. Listen for a stutter dial tone followed by regular dial tone.
  3. Dial the number where you want your calls forwarded.
  4. When the phone's answered -- either by a person or voicemail, hang up. ...
  5. Your calls will be forwarded to the number you dialed.
Use Call Forwarding to send your calls to another phone ' CenturyLink
www.centurylink.com/.../calling.../use-call-forwarding-to-send-your-calls-to-another-ph.....or try this link... How to Transferring call or call forwarding Google Search
Oct 23, 2017 | Lands Phones
How to active the follow me feature on a avaya partner phone 18d ?
Activation is easy, programming not so much. It's F11. There are about 10 conditions that have to be met, like the number has to be in peronal speed dial and call coverage needs to be on for outside lines to forward.
The form is F11.xx.xx
Carl
May 12, 2012 | Avaya Corded Phone avaparp18d
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
I have a panasonic KX-T7665 how do I forward calls to my mobile
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Carl
Mar 21, 2011 | Panasonic Lands Phones
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
Verizon blackberry tour froze, i took the battery out and it restarted but now i can only text and use the browser. I can not make or receive calls, i get an error message call forwarding conditional and i...
you will have to do a master reset this can be found in otions under security if running 5.0 it will be security wipe check all but the memory card and then hit ok then dial *228 choose option 1, if this does not work call *611 then choose option 3 for tech support if the phone is fairlly new they can replace it, they will have you try the same thing i just suggested and may resend service books to fix it. i had the same issue went back to my storm
Jan 17, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Message Indicator light displayed when there is no message
Don't know if you configured your CM server or not but there are two numbers that control the MWI. One number activates the lamp and the other turns it off. This is configured when you configure the system so I can't tell you what your numbers are. If you're using CM and not CME it's under the voice mail tab. Simply dial the number that turns the lamp off from the phones in question.
Oh and next time if you have an issue try restarting the CM service first instead of rebooting the box.
Jul 14, 2009 | Cisco 7960 IP Phone
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
I need to retrieve my home phone messages from cell phone
2. Press *7 2.
In some areas you must use 72#
3. At the tone, dial the telephone number where you want your calls transferred.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
