Question about Health & Beauty
Re CVS blood pressure cuff machine Model#BP3MU1-1E 800231, what does err 2 mean??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
My manual says that error two is unnatural pressure impulses influence the measurement result reason the arm was moved during the measurement remedy avoid unnecessary movement or talking.
Posted on Dec 02, 2016
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
PUT IN TIME/DATE ON CVS MODEL KD556 SKU 800231 BLOOD PRESSURE MONITOR, THERE R 2 BUTTONS, START & MEMORY : NO SET BUTTON
On your model, hold the "start" and "memory" buttons at the same time. After about 3 seconds the month will start flashing in the window. Push the "memory" button until it gets to the month you want. Then hit the "start" button and the day of the month will flash. Push the "memory" button until the correct day of the month comes up. Push the "start" button again, and the hours will flash. Push the "memory" button until the correct hour comes up. Do the same for minutes, and the next time you push "start" it goes into ready mode.
Apr 07, 2012 | Health & Beauty
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
My lifesource ua-767 displays err 3 is it the cuff or the machine
Turn it over tap little black gauge above battery cover with fingers turn on, err 3 code normally resolved.
Sep 25, 2010 | Lifesource Ua 767 Blood Pressure Monitor...
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
I have a medline b/p cuff model #MDS2001 and i get an ERR 3 on the screen. What does that mean
The cuff sensor must be placed directly over the vain. This takes a little practice
Jan 19, 2009 | Medline Industries MDS2001: Automatic...
Health & Beauty Logo
159 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
