I need a wiring diagram for a Dynamics terminator
It has 1vol 1output 1headphone output 1speaker 1battery and a circuit board
IFIXALL
  • 868 Answers
SOURCE: Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Posted on Jun 03, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
green_eyes_8
  • 53 Answers
SOURCE: need circuit diagram
Hello
try this link
http://www.irisvista.com/tech/laptops/ToshibaA65/satA65_1.htm
hope it helps
remember to vote and if you need any more info let me know.
good luck
Posted on Dec 05, 2008
SOURCE: mic wiring
Here is the wire diagram for the Galaxy:
1-SHIELD
2-MOD
3-TX
4-RX
I hope this helps you!
Posted on Apr 16, 2009
  • 5603 Answers
SOURCE: i need a wiring diagram for the main circuit board
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Posted on Aug 27, 2009
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Dynamics treadmill
LUBE THE DECK BELT, maybe the deck is work by lack of maintenance.
2) Adjust the roller bearing and lube.
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty.
sincerely. God bless you
Apr 19, 2012 | Exercise & Fitness
New goodman circuit board only 3 terminals where does yellow wire for a/c connect, no diagram on door.
If you are referring to the low voltage wire from tje AC then it goes on the Y terminal on the board.
Jun 25, 2011 | Heating & Cooling
No output voltage on circuit board terminals 1,2,3,and 4.
I think those are your thermostat connections and are probably 24 vac. Check the output of the transformer and make sure it is 24 vac. If it isn't make sure power is supplied to the input of the transformer.
May 02, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a JVC TM 9060U and a JVC BR 9050U (CCTV Monitor and recorder) which interfaced with my Gemini 3200 alarm system. I can't find any diagrams or instructions for the hardwire connections provided which...
The Napco GEMP3200 Control has 2 built-in alarm outputs. One on terminals 3, 4 & 5 and the other 6, 7 & 8. The first output is normally for burglary and is factory set for 12VDC output on terminals 3(+) and 5(-). If you don't have sirens in your system you can convert this output to a dry (no voltage) relay output by cutting Jumper B on the circuit board which is just right of those terminals. Likewise terminals 6(+) and 8(-) can be used as a relay output by cutting Jumper A which is also right of the terminals. However to use this output you will have to reprogram the system to make this output for burglary also. The easiest way,if you are currently using sirens in your system, is to go to a local electronics store and purchase a 12 Volt DC relay module for about $15. Run wires from terminals 3 & 5 to your relay's + and - inputs. The relay should provide a dry closure output which you can then run wiring to your recorder. When your system alarms it will not only set off your sirens but also trip the relay.
Nov 27, 2009 | Home Security
Oven lights not working. replaced both bulbs. both lights still not working. Is this circuit fused, if so, where is fuse located?. First problem on this Kitchen aid Superba in 12 years. John.
The oven lights get power from the main circuit board.
Access the circuit board and check output voltage on board terminals P4-4 to P4-1.
No voltage would be a bad board.
If you get voltage at these terminals the wires or sockets are bad.
The board is not repairable. Only replaceable.
Mar 15, 2009 | KitchenAid Kitchen Ranges
I need a wiring diagram for a 7 pin trailer board plug
Here's one
08-33-93f1.gif CAV CIRCUIT FUNCTION 1 Z13 12BK GROUND 2 B40 12LB TRAILER ELECTRIC BRAKE OUTPUT 3 L76 12BK/OR TAIL LIGHT (Trailer Tow Relay in PDC) 4 A6 12RD/TN* FUSED B(+) (40A, Always Hot, F8 in PDC) 5 L63 16DG/RD LEFT REAR TURN SIGNAL TRAILER TOW 6 L62 16BR/PK RIGHT REAR TURN SIGNAL CONNECTOR 7 L1 16VT/BK BACK-UP LAMP FIGURE 1: 7-Terminal Trailer Tow Connector
Mar 12, 2009 | 1993 Land Rover Defender
No output from circuit board
Doc,
I'm working on one of these chargers tonight. The white wire from the internal breaker is connected to terminal "PL" and the black wire to terminal "MS".
Hope this helps... Maybe you can fix my circuit board! Several fried components.
Jason
Jan 31, 2009 | RTO Mobil Line Mobility Scooter Chair...
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
