Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Side by Side. GSS25WGMD Bad Compressor
This refrig was less than a yr. old but was transported laying flat then turned on as soon as it was set upright. It now turns on and everything works (no clicking like I see people referring to) but will not cool at all. I am being told the compressor is bad. What is the ball park that we should expect for the parts and labor to have this replaced.
Thank you,
  • 447 Answers
Honestly, the compressor is under warranty for 5yrs i would not say anything about laying it down and call GE factory service.
Posted on Nov 20, 2007
Amana upright commercial freezer not freezing
did you lay it down during transport .if so it needs to stand unplugged for 24 hours .the oil will have run out of the compressor
Sep 26, 2016 | Amana Refrigerators
Refrigerator myth busted
Laying a refrigerator down to transport it if perfectly fine so long as it is stood upright for a couple hours before plugging in and turning on. The early refrigerator compressors could be damaged when the oil would drain from the compressor and refrigerant would mix with the oil (they have an infinity and are miscible). Modern refrigerators feature rotary or other than piston/reciprocating compressors that are much less vulnerable to damage go ahead and lay it down,
on Nov 01, 2017 | Refrigerators
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Need to transport an Admiral refrig about 20 miles to my home. Can I lay it on its back or side. It's a newer model, within 5-7 years old, I'm guessing. Any problems doing that/
Hi Bill
Its not the best idea to lay it down at all, inside the "pot" the compressor is suspended on 3 springs and it can get dislodged which wreck the compressor. However if you can lay it over at not less than 30 degrees from the horizontal (maybe in a pick up) and try not bounce it too much you should be OK.
This is because some of the oil from the compressor can get swirled out around the system when it's transported, if you do not give it time to migrate back then the compressor WILL SEIZE UP
Hope this helps
Apr 20, 2011 | Admiral Refrigerators
Is it ok to transport a refrigerator on it's side?
Not true. Refers since the 1950's are sealed units but for safety's sake let it sit for awhile after you move it.
Aug 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
Need correct setting for 30 yr old upright Kenmore freezer
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Feb 17, 2009 | Frigidaire Upright Freezer FFU12F2H
Enclosed find a link were you can get the answer for your question. Good luck !
Aug 16, 2007 | Magic Chef CTB2125 Top Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
