Question about Onkyo Audio Players & Recorders
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
  • Official Brand Answer
  • 333 Answers
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Posted on Dec 08, 2016
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 14 Answers
SOURCE: Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Posted on Jun 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do i connect my
Read the manuals...
http://filedepot.onkyousa.com/Files/own_manuals/tx_sv515pro.pdf
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
Posted on Jan 22, 2011
dunnbiker
  • 8546 Answers
SOURCE: What are the correct connections to connect a
Depends what you're trying to do with two amplifiers. Fill in the intent piece.
Posted on Apr 14, 2011
How do you connect a Jamo sub250 to a Onkyo tx-sr343 av receiver
You simply connect a RCA type line cable from the subs line input to the dedicated socket on the back of the Onkyo.
When you run speaker set up it will set the subwoofer up.
Jul 11, 2016 | Jamo "SUB250 250 Series Subwoofer, Single"
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Hum in Onkyo TX-SR505
I know that this is not Cheap But, If you want this to go away you need to Upgrade the A/V Cables to Monster Cables and it will Fix this Problem!
Dec 30, 2008 | Onkyo TX-SR505 Receiver
Onkyo SR-803 UNPOWERED Subwoofer conectio0n
HI,run speaker cables from "b" speakers out put to speaker in puts on the sub and switch "b" speakers on on the amp.
hope this helps.
CABLE GUY.
Jul 28, 2008 | Onkyo TX-SR803 Receiver
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Mar 24, 2008 | Onkyo TX-SR505 Receiver
175 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
