Question about HP Computers & Internet
Hp mother board model ms7336 cpu fan can"t detect no option enter to bios pls help me
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Hello, HP motherboards are very picky on what types of fans you install.
question: your cpu fan, does it have a 3 or 4 pin connector?
do you get error msg when you first turn on your computer about cpu fan not present?
also most hp,dell,compaq motherboards have very limited bios features to monitor fans and other hardware,
Posted on Dec 04, 2016
I have a intel dual core 3ghz cpu my mother board is Intel DG41RQ main board when on my computer the CPU fan is running but no display i check the CPU & ram and monitor that works fine on...
hello there
it seems that your on-board video card having trouble, try to put external video card to your system and power up your computer.
thanks.
Mar 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
My Compaq Presario SR2172NX desktop fan keep
Its good to keep like that since PCs need cooling regularly. Not like laptops. Laptops are designed based on architectures which provides cooling internally. Using copper pipes is an example. Anyway there are ways to control the fan speed. Before that check which fan that runs constantly. There are several fans in a system unit. Such as CPU fan, Graphic controller fan, chassis fan, extra coolers. First thing is that you have to adjust your power scheme. Go to control panel and then power options. Select appropriate settings.
If you use Vista as the OS this is a common problem since its visual effects eat the cpu. Specially that side bar and other things and drivers.
Check whether you have a process which is using 100% cpu using task manager. (Processes tab in task manager). If so either you have to stop it or terminate it of its a hanged program.
There are options to control the fan speed in your bios. Check the bios. To enter bios you can use one of these keys. Del, F2, F10 or Esc. One will let you in. Check the fan options and specially for a QFan option. You have to adjust the settings to control the fan. Finally there are hardware controllers which controls the fan speed near the fan (built in to the fan or near the fan's plug on the mother board). You can adjust them if you need to.
Please rate the answer if it helps you to overcome the issue. Thanks for contacting Fixya
May 31, 2010 | HP Compaq Presario SR1503wm PC Desktop
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Computer is not functioning
H!
Please check the lock of your processor. If it is tight or loose. If it is loose then it is the one causing the mother board no to function properly. You must tighten it to make it stable. After checking and it is not the reason for the malfunctioning of the system. Try to remove your CMOS battery and then clean, and remove also your memory card in the mother board and clean. Return it after cleaning and then close the CPU and turn it on. During the booting process strike the delete key to enter into bios set up. Adjust the time/ date settings to your current time. Press F10 then enter. wait for the CPU to process.
Please post any comment if it was solve so that I can give you more option if it does not solve your problem.
jonags3
Apr 17, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Booting problem
Check your harddisk connectio to mtherbord.reconneect both cable sata and power supply to harddisk.then check in bios your harddisk is detect or not.
Mar 21, 2009 | Intel Motherboard
Hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Nov 05, 2007 | HP OmniBook XE3 Notebook
Uncontrolled CPU fan speed
Make sure you have used the proper Fan connection on the motherboard and that you used all the pins in it. Usually it consists of 3 to 4 pins for CPU fans. Does your Fan have 3 pins? If not then it is not compatible for Fan Speeds. Also check your BIOS for Fan adjustments. Hope this helps.
Sep 15, 2007 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
178 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
