Question about Sharp Televison & Video
Picture was fine sound was fine suddenly white smoke and a gentle hissing sound emerging from the top of my sharp lcd 40" can anyone diagnose the issue pls
    Problem Solver:
  • 14 Answers
The white smoke - usually with a nasty smell will be a capacitor in (most likely) the power supply section. You will probably find one of the capacitor cans has a bowed and punctuered top. It's designed to fail that way with excess pressure. (If the top hadn't punctured, then the pressure would probably have blown the entire can off of its legs and made a mess on the PCB.)
Assuming it is a failed capacitor, it's probably a one-off (you'll find out!), so replace it like-for-like. Pay attention not only to the polarity and voltage rating, but make sure it is high-temperature rated (ususally 105C) and a low ESR type. Fittting a standard (non-lowESR) capacitor in a switch-mode power supply will lead to early overheating and failure.
(Obviously, if there's any detritus from the old capacitor, clean it off of the PCB first!!!) Good luck with that.
Posted on Dec 02, 2016
Testimonial: "wow well out my steady capability hands then!!! thank u for your reply you is spot on with diagnostic me main capacitor can lid has blown so I'm not able to just remove the top then?"
  • Sally Jelfs Dec 02, 2016
  • Sally Jelfs Dec 04, 2016
    If the top has blown off or punctured, it is because a fault occurred which caused the electrolyte inside to boil. (That's fatal to the capacitor!) Hence the white smoke. The capacitor may have failed on its own, in which case replacing it will fix the problem. But, if it was caused by some other component failure causing over-voltage or reverse voltage then it will quickly blow again. If this is the case, then you'll need more local hands-on help to find the root cause.
    (For others: had it been black smoke, it would most likely be a resistor or semiconductor toasting. That would be beyond the capability of this forum to easily diagnose.)
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Sharp lcd DVD error
Suggestion. Check the battery in the remote
Mar 21, 2014 | Sharp LC Televison & Video
I have a 46 inch LCD LN46A630. It was working fine and suddenly the screen when white. You can faintly see a picture beneath the white screen. I spoke with someone from Samsung that directed me to
It sounds that its main digital board has damaged. Video processor section has the fault. It has no repair at component level. Should be replaced as card basis. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Pull up older posts there.
Oct 15, 2012 | Samsung LN46A630 LCD TV
Samsung 40" lcd analoge picture fine . freeview picture fine but picture from scart is black and white . sound ok on all formats
REPLACED MAIN BOARD
Manufacturer Samsung LN40A450 Part Number BN96-07891C Description ASSY PCB P-MAIN;BN94
Nov 03, 2009 | Samsung LA40A450 40 in. LCD TV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
Vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
May 01, 2009 | Televison & Video
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
