Question about Teac Audio Players & Recorders
HOW TO OPEN THE CD TRAY TO INSERT A CD
TEAC DC02930
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Posted on Jun 21, 2009
  • 53 Answers
SOURCE: CD Tray will not open
Straighten a paper clip. There is a small hole the size of the paper clip on the front of most disk devices. Put the clip into the hole and the drawer should open.
read ya,
Zee
Posted on Dec 29, 2009
  • 105 Answers
SOURCE: The CD tray will open then automatically close
It could simply be that the gears inside are getting stuck, so they automatically retract.
Posted on Mar 02, 2010
The cd tray on my computer will not open
HI
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
The CD drawer refuses to open when I push the open button.
I know this sounds a little brutal for what is after all is a delicate piece of hi-fi; I've just fixed mine by turning it upside down and giving it a good shake, knocking the underside a couple of times. The tray jumps out of its guide track, you're just shakin it back in.
Oct 03, 2010 | Teac PD-H300 CD Player
Need to remove a CD from DVD drive when computer won't reboot
In a laptop drive, there is a small hole in the door near the "open" button. Gently push a straightened-out paper clip into the hole and the drive will open.
In full-size drives used in desktops, the hole is usually under the tray. Again, push a straightened-out paper clip into the hole to open the tray. Once the tray slides out you can open it the rest of the way by hand.
Mar 12, 2010 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
CD tray won't open
hi Dahanbury.
have a look on the front of the tray and see if you can see a very small hole.
insert the end of a straightened paper clip into the manual eject hole on the front of the drive,do not push it to hard just enough to see if it will open.
or go to this link and read up some more on this.
Use This Simple Trick to Open Your Stuck Disc Drive
if none of this is of any help to you,you may have to open it up and try and sort it from there.
Dec 14, 2017 | Audio Players & Recorders
CD drawer won't open
hi, try opening up the cover lid, and manually give a mild push to the tray, must be some small jam, or the eject belt or gear,.let me know
Dec 28, 2007 | Teac GF-300 CD Shelf System
TEAc HMX-760 "CD Drawer" was removed
you lost the cd tray timing,caused by force- eject,so you need proper alignment,you,needs specialist.
Feb 05, 2007 | Teac DC-D2831 CD Shelf System
CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
