My furnace will not ignite have new electrode gets gas no muddobbers nest inside
  • 51 Answers
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Posted on Sep 07, 2008
farfield
  • 462 Answers
SOURCE: Carrier Furnace 58gs075-1 Circuit board issues...
I cant see your wire diagram but trace the circut your talking about. I believe it usually goes through a series of safety switches. Put your VOM across each individual switch. If you get 24 out from the board the first 1 you check and get 24v is open and not feeding back to the board is out. FIND out why. the switch could be bad but it may be indicating a more involved problem, just look aroeund for chared wires or tell tell signes of flame roll out or if its an open (fuse link) suspect what can cause an over heat condition anythign from a bad board or too long an off cycle before the indoor fan comes on ect. PONIT IS Once you come across the cause may not be the reason.
Please grade me accordingly and if you need more I need more info from you.
Posted on Mar 02, 2009
SparkyNZ
  • 43 Answers
SOURCE: New stove gas is flowin
  • Where starting is manual (there is a 'start' position on the control(s), a set of switch contacts on the control(s) provides power to the ignition module.
    • A problem of no spark with only one control indicates that the fault is with it or its wiring.
    • A problem with continuous sparking even with all the controls off or in their normal positions indicates a short - either due to a defective switch in one of the controls or contamination (e.g., spilled liquid) bypassing the switch contacts.
  • Where starting is automatic, an electronic sensor, thermocouple, or bimetal switch provides power to the ignition module as needed.
Before you blame the ignition module for either lack of spark or continuous spark, make sure the wiring is in good condition and completely dry and clean ( or reasonably clean). Confirm that proper voltage is reaching the module with a multimeter or neon test lamp. The modules are quite robust:
  • Any liquid that may have dripped into the module may result in temporary or permanent failure. Fortunately it may be possible to pop off the bottom cover (with power OFF or the module removed!) and clean it. The most likely failure would be the SCR if you are into component level repair. Else, just replace it.
  • WARNING: There are several capacitors inside that may be charged to as much as 300 volts. The charge they can hold is probably not dangerous but may be painful or startling. Discharge these before touching anything inside or attempting to check components. Use a screwdriver blade or test clips and then confirm that they are discharged with a multimeter.
  • Contamination of the controls from spilled liquid may result in continuous activation of the ignition module since any electrical leakage across the switch contacts will likely be enough to activate it. Remove the control panel cover and dry it out or unplug the range or oven for a couple of days. If the contamination is not just plain water, it is a good idea to clean it thoroughly to prevent future problems.
  • Spills into the area of the electrodes at the gas burner assembly may short out the ignition for ALL the burners since they probably use the same module. Again, clean and dry it out or let it dry out on its own (if just water).
These are solutions for standard modules and replacements should be available from your local appliance repair shop or parts supplier. An exact mechanical match is not needed as long as the specifications are compatible.
Posted on May 11, 2009
  • 14362 Answers
SOURCE: no ignition on dayton gas furnace. how hard is it
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Posted on Oct 31, 2009
  • 3280 Answers
SOURCE: ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Posted on Jan 22, 2010
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Getting the heater to lite
Could be a multitude of causes. Here are a few common ones.
Igniter electrode dirty or corroded.
Igniter misaligned.
Failed circuit board.
No power to furnace.
Time delay switch defective.
Sail switch defective.
Overheat switch open/defective.
LP gas valve not opening. Check electrical connections before replacing valve.
Failed to purge system after storage. Light the stove and let it burn for a minute.
Manual LP valve (close to furnace) not opened.
Valve on main LP tank not open.
LP tank empty.
Feb 17, 2014 | RVs
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
No fire in box
Do the new electrodes emit an ignition spark? Just becuase they are new doesn't mean that the system that energizes them is functional. Have you tried a new igniter module?
Dec 15, 2011 | Heating & Cooling
FURNACE RUNS UNTIL IT REACHES ITS DESIRED TEMP
Could be cracked or misaligned electrodes. Could be improperly gapped electrodes. Make sure transformer is making contact with the buss bars. Make sure transformer is secured down. Make sure your air setting is not to high, or else it will blow out the spark before ignition. Hope this helps
Apr 24, 2009 | SySTOR Systems (400S52) Burner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
