Question about Car Audio & Video
What's does d3 mean - Car Audio & Video
I HAVE GOT CODE D3
D3. from what, name it? D3 is a shifted gear, (A/T)
there is no code D3, not in the opr. guides.
odometer code? B3? radio codes, NAV codes , WHERE?
how much is alot, ??????????? alot means zero.
5 mpg?
10,15? what?
did you lose the operators guide ?
in glove box, (look)
see it free here , get it and keep it at all times
http://justgivemethedamnmanual.com/honda/honda-accord-coupe-owners-manuals/
burn it to mem. stick.
Feb 15, 2014 | 2005 Honda Accord
Capacitor failure
this is not :d3: its should be "de" mean door swich error,
Jan 28, 2014 | LG Washing Machines
When do I use the d 5 gear in acura 2003 tl 3.2 liter
Pretty much all the time!
D3, D4, and D5 are all just *DRIVE* like on any automatic transmission, EXCEPT
that the number next to the D is the "highest gear the automatic transmission will go into".
The Acura just gives you a choice, in case you don't want to go into a higher gear (like if it's slippery traction or a steep hill, etc.)
1 means: Manual gear. FIRST GEAR ONLY.
2 means: Manual gear. SECOND GEAR ONLY.
D3 means: Use automatic transmission, but engine will never shift above 3rd gear.
D4 means: Use automatic transmission, but engine will never shift above 4th gear.
D5 means: Use automatic transmission, but engine will never shift above 5th gear.
Aug 04, 2011 | 2003 Acura 3.2TL
"D3" on Renault Megane Scenic
3rd gear or all drive gears up to 3rd forward
Jul 19, 2009 | 2003 Renault 181
Using 2004 honda accord auto transmission
d will do just fine but most say city driving use d3 but at higher speeds you will burn more gas because the car will rev higher
Jul 03, 2009 | 2004 Honda Accord
Warning lights on dashboard
Try pressing the D3 button on your gear shift - little button below the main one. D3 allows for quick acceleration, but the light also shows when the car is locked is gear ('limp home mode') due to another problem.
Jan 29, 2009 | 2000 Renault 181
What does d3 mean?
it is related to something like cleaning the washer drum.
Dec 11, 2008 | Zanussi FJS1225W Front Load Washer
I just picked up a 87 honda accord and just want to know what gear i drive it in it has l2 d3 and d4 can you help got me confused
D4 - this gear means that all four automatic gears will be able to work (1,2,3,4)
D3 - Three gears will be able to work (1,2,3)
D2 - Two gears (1,2) - L2 means the same thing
D1 - One (low) gear (1)
For your car, drive it in d4. this means that all forward gears will work, including overdrive (4th gear). It will be fine to leave your car in this gear.
Jul 20, 2008 | 1992 Honda Accord
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
