Question about The Watches
I replaced the battery in my blackberry label watch everything works except hands will not move but I can wind the will and move them am I supposed to do anything special to start this feature
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
Posted on Aug 12, 2008
Press MODE 5 times until you see H-SET on the right side of the dial in the box. Then press the ADJUST button. You will now notice the current TIME you have already set on your watch will appear in the box and flash where H-SET was. This will help you know what time to set the hands on. While holding down the FORWARD button you will see the hand start to move. I could not move mine in reverse, only forward. Simply set the time and you are finished.
Posted on Dec 26, 2008
  • 4 Answers
SOURCE: watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Posted on Feb 16, 2009
  • 61 Answers
SOURCE: My watch no longer functions even after winding.
I have found that some of these "automatic" Fossils also contain a battery. That is how that provide an automatic watch at such a cheap price. I recommend taking it to a jeweler to have them check this. If it needs repair it will likely cost near the watche's replacement value.
Posted on Oct 17, 2009
Testimonial: "Thanks Admiral Adam, you provided some valuable insight into my problem"
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
Have new battery lite works and digital working i tunn hands like to wind it and they move
The hands are sliding at the base. set at 3:00 and a drop of crazy glue should move them when set.
good luck
Apr 22, 2017 | Watches
Which way is clockwise as you hold it in your hand and one time that i set it it went around by it self another times i had to wind manually
Clockwise is the way you read the numbers 12,1,2,3,4,5, etc. the way the hands move. If there s a digital display that is supposed to match the hands, Set it first then find the menu setting for hands
Nov 23, 2015 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock and hold the top right hand button and the hands will start can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
The hands are not moving. Do you manually wind cross watches? Does it work from a battery?
Push the crown in, flush with case and turn it anti-clock wise. If you do not hear any clicking sound whilst doing that - your watch is battery driven. If you hear clicking sound - your watch is spring driven (mechanical).
Rate me, please.
Aug 05, 2010 | Cross Watches
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
I have a watch that is supposed to wind itself by the movement of my wrist rocking around the wheel and it has stopped.
How old is the watch? If its an older automatic watch it might need to be cleaned! There are 2 types of auto wind watches. Springs or capacitor! If its a spring then take the watch off of your wrist and while holding it in your hand gently rock it back and forth. You should feel the weight moving around inside. If its a capacitor and doesnt start to run after you gently rock it in your hand then you need to take it to a watch repair business and see if they can replace the capacitor!
Jan 09, 2010 | Diesel DZ7044 Watch
Oct 16, 2009 | Fossil Batman Rotor Style Automatic...
I can't get my head around how to manually wind my Fossil ME1020
You are not supposed to wind the watch, in simply winds itself with the motion of your wrist. A weighted wheel located in the back of the watch winds a spring that powers the second hand. The minute and hour is power by quartz and a battery.
Apr 05, 2009 | Fossil ME1020 watch
Red hand for dual timezone
If your watch has mechanical- self winding movement, then ALL the gears, hands and functions are mechanically driven and executed. None of the hands can be winded, as the movement of the hands is the consequence of the releasing power of the winded mainspring. All hands (including dual time zone hand) can be udjusted only to the required time and the rest is done automatically by the gears, cogs and levers.
If the dual time zone hand is not functioning properly- there is some mechanical fault and you will have to get the watchmakers help to sort it out.
Do not forget to rate, please.
Mar 07, 2009 | Breitling Navitimer A2332212 G5 431A watch
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to and find out.
Dec 16, 2008 | Invicta Speedway 9223 Wrist Watch
Watches Logo
22 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
