Resetting my all in one desktop - Computers & Internet
  • Erick Shepherd
    Erick Shepherd Dec 02, 2016
    Are you having difficulty rebooting it? The image doesn't expand: Could you type the text displayed on the monitor into the comment box?
Tracking arrow don't move
I'd recommend replacing the mouse with another known good working mouse-- just to test it out.
You could also try resetting the PMU.
Resetting the iMac Flat Panel Power Management Unit PMU
Hope this helps!
Feb 26, 2015 | Apple iMac G4 Desktop
R630 keeps resetting after boot up.
Repair your opearing system of the desktop.
Aug 19, 2011 | Fujitsu CELSIUS R630 PC Desktop
Imac intel dual core dvd drive will not mountunable to load a cd or dvd it keep ejecting them. I have tried to boot with the OSX CD, but still it eject it out. I notice the problem when I tried to...
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
If that doesn't work, try resetting the PRAM:
If these do not resolve the issue you will likely need repair.
Jun 20, 2010 | Apple iMac Z0CY Desktop
Is flashing the BIOS the same as resetting the BIOS? I to am going to upgrade to a 5400+ AMD CPU. mobo: MCP61-AM-6A61KE11C-00 BIOS version Ro1-B3. I'm having a hard time finding a flash for this version....
Hi, flashing the board and resetting it is not the same. flashing the board is downloading the firmware and installing in on the motherboard but resetting the bios is just moving a jumper found on the board to reset it to default state. try to get on the manufacturer website to get the flash files. Be careful flashing a motherboard may be very risky and harmful for the motherboard.hope that it helped and don't forget to rate.
Best regards
Damien C
May 23, 2010 | Acer Aspireā„¢ T180 PC Desktop
I have a sony vaio pcv-w1 desktop computer,is there a way in resetting back to manufactory settings without a recovery disk
no there is no way to recover it back if you diddnt did the recovery disk when you bought your computer.
Jan 25, 2010 | Sony VAIO PCV-W1 PC Desktop
I plugged my Acer desktop computer into 220 without switching the voltage - bang - circuit breaker tripped - can i reset the power supply?
yes you can try resetting it, make sure its on the right voltage setting, i hope the fuse is not broken, after resetting and it doesnt power on, please have it checked by acer service center
Oct 19, 2009 | Acer AX1200-U1520A PC Desktop
My desktop icons keep resetting thier order/layout.
Okay, well check your graphics properties to make sure you aren't saving your desktop profile and reloading it every time windows starts. It shouldn't be automatically turned on, but if it is, it will have taken a snapshot of your system at some point, and it will reload the snapshot of how your desktop is supposed to be each time you restart windows. It can also load your settings such as auto-arrange on.
That should fix any problems you have about the computer resetting itself. As for where that's located, I can't give a general idea, it depends on your card and drivers, but I have Windows Vista Home Premium as well and I know the option should be there
Mar 29, 2009 | HP Pavilion m8020n PC Desktop
Resetting the bios password a on acer travelmate 2356xm
This web link will give you different options on resetting and clearing the bios password. The easest way is taking out the battery if not smoldered in for 30 min. then on post boot press f2 to get to bios.
Jul 14, 2008 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
